Cluster size distribution
Dear LAMMPS Users
We are trying to simulate the dipolar LJ particles in two dimensions to study the aggregation behaviours as function of temperature and number of particles. For this we need to calculate cluster size distribution. We have used “cluster/atom” key to evaluate this but some how it is working and showing following
ERROR: Illegal compute cluster/atom command (…/compute_cluster_atom.cpp:40)
fix 3 all ave/histo 100 1 100 0 20 20 c_size mode vector ave running beyond ignore file tmp.histo
Please suggest the way to rectify this. I am also attaching my script used for this.
Point dipoles in a 2d box
units lj
atom_style hybrid sphere dipole
dimension 2
lattice sq2 0.3
region box block 0 10 0 10 -0.5 0.5
create_box 1 box
create_atoms 1 box
need both mass settings due to hybrid atom style
mass 1 1.0
set group all mass 1.0
set group all dipole/random 98934 1
velocity all create 0.0 87287 mom no
pair_style lj/cut/dipole/cut 1.122 46
pair_coeff * * 1.0 1.0
neighbor 0.3 bin
neigh_modify delay 0
fix 1 all nvt/sphere temp 1.0 1.0 0.01 disc update dipole
fix 2 all enforce2d
timestep 0.001
compute erot all erotate/sphere
compute syTem all temp/sphere
thermo_style custom step temp epair c_erot etotal press
thermo 500
compute cluster all cluster/atom 1.2
compute cc1 all chunk/atom c_cluster compress yes
compute size all property/chunk cc1 count
dump 1 all custom 100 dump.dipole01* id type x y z mux muy
#dump 1 all image 250 image.*.jpg mux type &
zoom 1.6 adiam 1.2
#dump_modify 1 pad 5
run 100000
regards
Manish Anand
Dear LAMMPS Users
used "cluster/atom" key to evaluate this but some how it is working and
showing following
ERROR: Illegal compute cluster/atom command (../compute_cluster_atom.cpp:4
0)
used for this.
​apart from an easily fixable issue with a neighbor list overflow due to
the unusually large cutoff on your pair style, this input runs without a
problem using the latest LAMMPS patch version (5 Feb 2018). you failed to
mention the LAMMPS version you are using? please note, that the online
documentation always refers to the current patch version and that commands
can change in non-backwards compatible ways as listed here:
http://lammps.sandia.gov/bug.html
