Clusterexpand -pa svib_ht
I don’t understand why I’m getting this error message:
mg2sisn (ruth) 1097 >clusterexpand -pa svib_ht
cp: overwrite `allsvib_ht.out’? y
terminate called after throwing an instance of ‘std::bad_alloc’
what(): std::bad_alloc
Abort
tail: n: invalid number of lines
awk: cmd. line:1: (FILENAME=- FNR=1) fatal: division by zero attempted
awk: cmd. line:1: (FILENAME=svib_ht.ecimult FNR=1) fatal: division by zero attempted
The file svib_ht.ecimult is:
-87.7348
-0.47771
-0.0910951
-0.111583
-0.14271
0.0584983
-0.166649
-1.77249e-05
0.176929
-0.00131653
0.0417185
0.108665
0.107429
-0.0755752
-0.0583958
-0.0099935
0.116252
0.0340056
-0.0081235
-0.0563991
0.140992
0.00108487
0.000758359
0.120276
-0.151708
-0.0823292
-0.0743108
0.0094169
-0.0482484
0.0239537
0.00664155
-0.000182096
-0.000981038
0.00060414
Sorry for the delay in answering!
Can you send me the output of
tcsh -v -c clusterexpand -pa svib_ht
so I can debug.
mg2sisn (alfred) 115 >tcsh -v -c clusterexpand -pa svib_ht
Unknown option: `-pa’
Usage: tcsh [ -bcdefilmnqstvVxX ] [ argument … ].
Sorry, I should have asked:
tcsh -v -c "clusterexpand -pa svib_ht"
(with quotes around the command)
This seems to yield the same result:
mg2sisn (alfred) 116 >tcsh -v -c "clusterexpand -pa svib_ht"
Abort
mg2sisn (alfred) 117 >
Ok - can you send me your input files, i.e.
tar -cvf foraxel.tar lat.in */str.out */svib_ht
(I need this to debug.)
File attached, generated with:
Sorry, the command actually works fine over here. I need more information, do:
emacs `which clusterexpand`
(or any other text editor instead of emacs)
edit the first 2 lines of the file to read
#!/bin/csh
set verbose=1
then
and send me the output you see.
To save another iteration, can you also send the file generated by
tar -cvf foraxel2.tar *.out *.tmp *.log *eci*
Then again, maybe not:
mg2sisn (alfred) 127 >clusterexpand -pa svib_ht
if ( $#argv == 0 || "xx$1" == "xx-h" ) then
set skiperror=""
while ( $#argv != 0 )
set theopt=echo $1 | sed 's/=.*//g'
switch ( theopt ) set nodivideperatom breaksw shift end while ( #argv != 0 )
switch ( $theopt )
break
if ( "x$2" != "x" ) then
echo -n "" > ! allstr.out
echo -n "" > ! allstrname.out
echo -n "" > ! all${1}.tmp
echo -n "" > ! allnbatom.out
foreachfile $skiperror $1 pwd > ! allstrname.out
if ( cat allstrname.out | wc -l == 0 ) then
foreachfile $skiperror 1 'cat str.out; echo end; echo ""' > ! allstr.out if ( ?usegce ) then
foreachfile $skiperror $1 "nltoblank < 1 ; echo ''&quot; &gt; ! all{1}.tmp
set nbrep=1
endif
foreachfile $skiperror $1 ‘cat str.out | cellcvrt -pn’ | awk ‘{for (i=1; i<=’$nbrep’; i++) {print $1} }’ > ! allnbatom.out
if ( ?nodivideperatom ) then cp -f all{1}.tmp all${1}.out
else
rm -f all${1}.tmp
if ( $?usegce ) then
corrdump -c -s=allstr.out > ! allcorr.out
Abort
endif
if ( $?selectcol ) then
lsfit -colin -x=allcorr.out -y=all${1}.out > ! {1}.ecimult if ( ?printcv ) then
endif
cat lat.in | cellcvrt -f | tail -n +7 | wc -l > ! nbinlat.out
getclus | awk ‘BEGIN {getline < "nbinlat.out"; l=$1} {print $3/l}’ > ! clusmult.out
awk 'BEGIN {while (getline < "clusmult.out") {c++; m[c]=$1;} maxc=c; c=0;} {if ($1 != "") {c++; print 1/m[c]} else {c=0; print &quot;&quot;}}' {1}.ecimult > ! ${1}.eci
mg2sisn (alfred) 128 >> lsfit -x=allcorr.out -y=allsvib_ht.out -cv -s=1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
-x=allcorr.out: Command not found.
ok, I can see what command fails, but I still need the foraxel2.tar file I asked you to send.
