CMake Error at CMakeLists.txt:208 (find_package)
Dear Lammps experts,
I am going to install the KSPACE package on lammps-june2019. Actually when I apply the below command in order to install all packages, I will face with this error:
cmake -C …/cmake/presets/all_on.cmake [OPTIONS] …/cmake
error:
CMake Error at CMakeLists.txt:208 (find_package):
By not providing “FindADIOS2.cmake” in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by “ADIOS2”, but
CMake did not find one.
Could not find a package configuration file provided by “ADIOS2” with any
of the following names:
ADIOS2Config.cmake
adios2-config.cmake
Add the installation prefix of “ADIOS2” to CMAKE_PREFIX_PATH or set
“ADIOS2_DIR” to a directory containing one of the above files. If “ADIOS2”
provides a separate development package or SDK, be sure it has been
installed.
So, it seems that cmake package is not update and I should update it. am I correct?
Yours Sincrely,
No, you are wrong. Please read the documentation more carefully.
You may use make command because it’s quite simpler to use as compared to cmake.
“make yes-kspace”
Ok, thanks.
I have just re-build lammps as per https://lammps.sandia.gov/doc/Build_package.html and the problem has been solved . but new -users please be careful, before "make mpi "command, mpi module shall be loaded first !!! (I have not found it in the document)
best regards,
