Cohesive energy calculated by ReaxFF for fcc Gold much higher than EAM force field
I am trying to test the ReaxFF from bulk optimization for fcc Au lattice. By changing gold lattice parameter from 3.0 to 5.0 Angstrom, I got the right Energy VS distance curve shape as below. However, the total energy and pressure calculated are extremely high about -333 eV and 5505330 bar when lattice constant is 4.0 Angstrom. But for EAM potential, the energy and pressure is good - -15.58eV and 115574 bar.
The optimization curve for ReaxFF is attached. The input file of reaxFF is below, which I revised some parts from the lammmps tutorial 2 of Al to reaxFF of Au.
Do I need to add another fix command to fix temperature ? What is the key reason that the total energy and cohesive energy calculated by this script are so high?
6 clear
7 units metal
8 dimension 3
9 boundary p p p
10 atom_style charge
11
12
13 # ---------- Create Atoms ---------------------
14 lattice fcc ${latconst}
15 region box block 0 1 0 1 0 1 units lattice
16 create_box 1 box
17
18 lattice fcc ${latconst} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
19 create_atoms 1 box
20 replicate 1 1 1
21
22 mass 1 196.966
23 set type 1 charge 0.0
24
25 # ---------- Define Interatomic Potential ---------------------
26 pair_style reax/c NULL
27 pair_coeff * * ffield.reax.AuO Au
28
29
30
31
32 # ---------- Run 0 ---------------------
33 fix 1 all qeq/reax 1 0.0 10.0 1e-6 reax/c
34 run 0
35
36 variable natoms equal “count(all)”
37 variable teng equal “pe”
38 variable length equal “lx”
39 variable ecoh equal “v_teng/v_natoms”
40
41 print “Total energy (eV) = ${teng};”
42 print “Number of atoms = ${natoms};”
43 print “Lattice constant (Angstoms) = ${length};”
44 print “Cohesive energy (eV) = ${ecoh};”
45 print “%% ecoh = ${ecoh};”
46
47 print “All done!”
Really appreciate your help!
Zhi
reaxFF of Au.
are so high?
6 clear
  7 units metal
wrong units?
In addition, there is no meaning in comparing the absolute energies from different potentials at specific lattice constants. What makes sense is to look at the shape and 1st derivative of the E-V curve from each of the different potentials.
Ray
