Dear Lammps users,
I’ve encountered a strange problem when using com/chunk and vcm/chunk computes: defining chunks to be polymer atoms of 3 different polymer chains in water works well for calculation of MSD and gyration radii of corresponding chains/chunks, however center-of-mass and its velocity are always inf-numbers or unphysical values of 10^8. I suspect a bug in the output of these 2 quantities, since MSD, which tracks the value of COM of each chunk looks pretty normal even for long simulation runs over 1 ns. Below is the portion of input script used for test case:
units real
atom_style full
variable Na equal 1000000
variable T equal 320.0
variable tstep equal 1.0
pair_style lj/long/coul/long long long 10.0
bond_style harmonic
angle_style harmonic
dihedral_style opls
improper_style class2
read_data 3decamer.data
include pairparameters.dat
group poly type 1 2 3 4 5 6 7
group water type 8 9
compute NIP poly chunk/atom molecule nchunk once ids once
---------- Run Minimization ---------------------#
reset_timestep 0
fix 1 all box/relax iso 1.0 vmax 0.001
thermo 100
thermo_style custom step pe etotal lx ly lz press pxx pyy pzz
min_style cg
minimize 1e-6 1e-6 5000 10000
unfix 1
write_restart restartfile.minimized
velocity all create ${T} 4928459 mom yes rot yes dist gaussian
compute RG poly gyration/chunk NIP
compute MSD poly msd/chunk NIP
compute COM poly com/chunk NIP
compute VCM poly vcm/chunk NIP
fix 2 all nvt temp {T} {T} 50
fix PRINT poly ave/time 10 1 10 c_RG c_COM c_VCM c_MSD file polymer.out mode vector
run 1000
the output of the ave/time script is as follows:
0 3
1 6.7764 0 0 0 -inf -inf -inf 0 0 0 0
2 6.58678 0 0 0 inf inf -inf 0 0 0 0
3 7.08112 0 0 0 -inf inf inf 0 0 0 0
10 3
1 6.82073 0 0 0 inf -inf -inf 0.00544238 0.0675754 8.38274e-09 0.0730178
2 6.81958 0 0 0 inf inf inf 0.192354 0.325749 0.015632 0.533736
3 6.80645 0 0 0 -inf inf inf 0.00193617 0.26595 0.0158504 0.283736
20 3
1 6.80703 0 0 0 inf -inf -inf 0.00518961 0.0665801 5.39325e-05 0.0718236
2 6.79353 0 0 0 inf inf inf 0.19582 0.320532 0.0162308 0.532583
3 6.7816 0 0 0 inf inf inf 0.00183996 0.267282 0.0171962 0.286318
30 3
1 6.77937 0 0 0 inf -inf -inf 0.0046755 0.0653146 0.000196425 0.0701866
2 6.75628 0 0 0 inf inf inf 0.199732 0.315468 0.0168438 0.532045
3 6.74668 0 0 0 inf inf inf 0.00143704 0.268844 0.0186708 0.288952
I have tried different initial configurations and restarts from previous runs, still no luck with COM and VCM portion, though MSD and gyration radii look reasonable to me. Any ideas, thoughts?
If needed, the initial configuration can be provided as well.
Vitalie
