Dear lammps users,
Hello, everyone! I’m trying to compute the g® of COM of polymer, the lammps command only compute the g® between the atoms. I read previously thread in lammps forum, and what they mentioned is I need to build a script for calculating COM and defined the molecules. I’m wonder anyone have a better way to do the molecular g® calculation. Any help would be appreciated.
Thanks !
Kerwin
Dear lammps users,
Hello, everyone! I'm trying to compute the g(r) of COM of polymer, the
lammps command only compute the g(r) between the atoms. I read previously
for calculating COM and defined the molecules. I'm wonder anyone have a
better way to do the molecular g(r) calculation. Any help would be
appreciated.
please keep in mind, that a g(r) is a property which computes the
relative probability of point particles in a given system versus the
distribution of an ideal gas.
so any application to molecular systems is of limited meaning.
the easiest approach is usually to pick the atom that is closest to
the center of mass, give it a different atom type number (but the same
force field parameters) and then compute the g(r) for that type of
atom. if you average over a large enough system and long enough
trajectory, the differences to the g(r) of the COM should be
negligible.
a more involved approach would be to compute the COM(s) and output it
to a file and then compute the g(r) in post-processing.
Thanks for you information! Can you say anything specific about the second method for computing molecular g®? The question is, how to define this COM of molecules to particle and output to trajectory which can use to compute the molecular g®? I used the example command to compute the COM of molecule. If i want co continue, what command would be helpful, dump or restart ?
The example command for computing COM of molecule:
compute cc1 all chunk/atom molecule
compute myChunk all com/chunk cc1
fix 1 all ave/time 100 1 100 c_myChunk[*] file tmp.out mode vector
Kerwin
Dear lammps users,
appreciated.
please keep in mind, that a g® is a property which computes the
force field parameters) and then compute the g® for that type of
trajectory, the differences to the g® of the COM should be
negligible.
to a file and then compute the g® in post-processing.
method for computing molecular g(r)? The question is, how to define this
compute the molecular g(r)? I used the example command to compute the COM of
restart ?
neither. like i wrote, this is a post-processing task. so you need to
write a little program to read the tmp.out file and compute the g(r)
from it yourself.
this is a frequent assignment in graduate level statistical mechanics
classes, and there plenty of examples on the web. you just need to
adjust it for this specific case.
