Thanks a lot! If you can send me an example code, that would be great!
Sincerely,
Kerwin
If you are new to programming, you can check out my website: www.hypermd.wordpress.com.
Also, I will try to send you my code for calculating g® later.
Shafat
please apply some common sense and just do a web search. there should
be a *ton* of examples for how to compute a g(r) floating around on
the web.
also, if you convert your COM output file into a suitably formatted
trajectory file, you can use existing codes that post-process
trajectories. there are plenty of those around as well.
Thanks for your advice and help. I did the g® calculation and it works well.
be a ton of examples for how to compute a g® floating around on
the web.
