Hello all,
I am quite new to using potential models from the kim repository. I have installed the kim api version 2.1.2 and build lammps with the kim package. I wish to use the following model
MEAM_2NN_Fe_to_Ga__MO_145522277939_001. However, as I tried to obtain the kim model I got an error stating
*** ERROR *** MEAM_2NN_Fe_to_Ga__MO_145522277939_001 found at openkim.org is not compatible with this version of the KIM API.
I am able to obtain potential models with API version 2 and above
I could see that the version of API mentioned with this model is 1.6.
Thus, I wished to confirm whether the issue with compatibility is due to the version of API or some other reason.
Thanks in advance
