I am trying to simulate brwownian dynamics of dipole suspensions under shear. I use fix deform to shear the simulation box. Is this a legitimate thing to do? In other words, are the Lees-Edward BCs i.e. oblique cell compatible with electrostatic code? I appreciate your response.
as has been pointed out repeatedly on this list, LAMMPS does not do
Lees-Edwards boundary conditions.
My simulations show that most likely the electrostatic code does not work fine with fix deform i.e. it seems there is a localized shear strain at the box boundaries. This might be a bug.
I am attaching a movie with 9 periodic cells and my scripts. Please look how chains break at the boundaries due to a localized shear strain which is not present inside the simulation box. Here are my ingredients:
Polarized particles with 20% volume fraction and zero charge (i.e. dipole interactions)
A repulsive WCA core
External field is on
Suspension is under a constant shear rate (i.e. fix deform)
what makes you think this is due to electrostatics?
from superficially looking at your input, it seems more likely to me
that you need to re-read some of the "IMPORTANT NOTE:" sections in the
fix deform documentation.
I remap velocities and use a Langevin thermostat which according to the documentation should be fine. But the problem is still there. There is a discontinuity in shear strain at the boundaries. I agree it is not necessarily from electrostatics but something looks not correct.
that is not how i read the documentation. it is very straightforward
and explicit. and it just makes sense, if you think about it: since
fix langevin is a dissipative thermostat , you *have* to include a
bias consistent with your deformation, or it will mess up your
dynamics since it will try to dissipate your velocity gradient (and
the corresponding temperature gradient).
