compilation issue?
I am trying to update lammps and am having a bit of trouble. I went ahead and just started with a clean install, because doing a git pull wasn’t working.
I precompiled the packages in the lib.
I execute the following
make yes-standard
make package-update
then make openmpi
The last few lines of output from the make are given here below. There are pages and pages of similar output preceding this:
pair_yukawa_gpu.h:16:1: error: expected unqualified-id before âelseâ
In file included from style_pair.h:241:0,
from force.cpp:165:
pair_yukawa.h:16:1: error: expected unqualified-id before âelseâ
In file included from style_pair.h:242:0,
from force.cpp:165:
pair_yukawa_omp.h:20:1: error: expected unqualified-id before âelseâ
force.cpp:168:3: error: expected unqualified-id before âelseâ
force.cpp:169:3: error: expected unqualified-id before âreturnâ
force.cpp:170:1: error: expected declaration before â}â token
force.cpp: In member function âLAMMPS_NS::Pair* LAMMPS_NS::Force::new_pair(const char*, const char*, int&)â:
force.cpp:156:3: warning: control reaches end of non-void function [-Wreturn-type]
make[1]: *** [force.o] Error 1
Any ideas?
Hmmm ... I don't see this problem.
Is this with the most current version tarball?
The corrupted characters like âelseâ
are odd. Can anyone else verify a build
issue with the most current tarball? Maybe
Axel has an idea ...
they are not odd, they are a consequence
of cut-n-paste from a UTF-8 encoded native
language setting to a plain ASCII application.
basically all current linux distributions use NLS.
this can be avoided by using the C locale via:
export LC_ALL=C
i think the issue is the unneeded
make package-update
if i remember correctly, the GPU package
doesn't handle this well, since it provides
files that require user packages. i would
try to do:
make no-gpu
make yes-gpu
and see if that fixes the issue.
the real error has to be earlier in the output
from what was shown.
See comments below.
Hmmm … I don’t see this problem.
export LC_ALL=C
Yes, this fixed the funny characters. I am logging in to my machine remotely using putty which caused this.
Axel has an idea …
I just got the file with git before I started. So yes, it is the most current. Did a git pull too which said package is up to date.
make package-update
doesn’t handle this well, since it provides
try to do:
make no-gpu
make yes-gpu
Nope, doesn’t work. I tried this. I also tried
make no-all
make yes-standard
make no-kim
When I do a
make package-status
it shows that I am missing all kinds of files with in both cuda and gpu packages
Installed YES: package GPU
src/pair_lj_sdk_coul_long_gpu.cpp does not exist
src/pair_lj_sdk_gpu.cpp does not exist
src/pair_lj_sdk_coul_long_gpu.h does not exist
src/pair_lj_sdk_gpu.h does not exist
Installed YES: package USER-CUDA
src/pair_lj_sdk_coul_cut_cuda.cpp does not exist
src/pair_lj_sdk_coul_debye_cuda.cpp does not exist
src/pair_lj_sdk_coul_long_cuda.cpp does not exist
src/pair_lj_sdk_cuda.cpp does not exist
src/pair_lj_sdk_coul_cut_cuda.h does not exist
src/pair_lj_sdk_coul_debye_cuda.h does not exist
src/pair_lj_sdk_coul_long_cuda.h does not exist
src/pair_lj_sdk_cuda.h does not exist
making from this point now gives me a different error: (is that progress?)
verlet_cuda.cpp: In member function ‘void LAMMPS_NS::VerletCuda::test_atom(int, char*)’:
verlet_cuda.cpp:1075:145: warning: format ‘%i’ expects argument of type ‘int’, but argument 4 has type ‘LAMMPS_NS::bigint {aka long int}’ [-Wformat]
make[1]: *** [verlet_cuda.o] Error 1
There were so many errors that I am filling the terminal buffer. Is there a way to dump compilation output to a file? The obvious make foo > filename doesn’t seem to work. I should be able to increase the buffer size when I am on the actual computer at work, my remote terminal won’t let me.
export LC_ALL=C
yup. i have learned to hate NLS.
at least in science, computers should
speak plain 7-bit ASCII and english.
everything else creates a gazillion
of unexpected problems. i've been
through some crazy stuff myself.
try: git status
or: git diff
the up-to-date from git pull only means that you have
checked out the up-to-date repository. with the big
whitespace patch from a couple days ago, things
could get a little ticklish if you have local modifications.
Nope, doesn't work. I tried this. I also tried
make no-all
make yes-standard
make no-kim
When I do a
make package-status
packages
this is fine. these are the problematic files that
will mess up things when you do a
make package-update
since they are dependent on a user package
(USER-GC-CMM). i've been able to fix this
issue for USER-OMP (which has components
for many optional packages) with some crazy
shell scripting, but i have not had the time to
apply this to those other packages.
verlet_cuda.cpp: In member function 'void
LAMMPS_NS::VerletCuda::test_atom(int, char*)':
verlet_cuda.cpp:1075:145: warning: format '%i' expects argument of type
'int', but argument 4 has type 'LAMMPS_NS::bigint {aka long int}' [-Wformat]
this is just a warning. USER-CUDA could use a few little
tweaks. i have them fixed in LAMMPS-ICMS, btw, but
have not gotten around to feed it to christian.
nevertheless, there has to be something else.
just try compiling w/o USER-CUDA for now.
i personally never compile in GPU and USER-CUDA
at the same time and have separate settings for
them (since USER-CUDA requires run-time type
information, which results in a significant slowdown
for the rest of the code. compiling with -fno-rtti and
-fno-exceptions is highly recommended, if you need
to squeeze out every little bit of performance.).
doesn't seem to work. I should be able to increase the buffer size when I am
on the actual computer at work, my remote terminal won't let me.
that redirects only the standard output. errors are sent to the standard error,
which is file descriptor 2 and not 1. in bash or (t)csh you can do
make foo >& mk.out
otherwise in bourne/korn shells:
make out > mk.out 2>&1
standard unix stuff...
HTH,
See below. In summary make no-user-cuda failed.
try: git status
or: git diff
Well, I started fresh with a new clone first (rather than just updating), so I assume I got the latest greatest w/o any modifications anywhere.
Okay so I tried:
make no-user-cuda
Uninstalling package user-cuda
then when I
do make package-status
it says:
src/atom_vec_angle_cuda.cpp does not exist
src/atom_vec_atomic_cuda.cpp does not exist
etc…
so that’s weird. It looks like it still thinks it should compile the package, but all the files are gone.
then when I make it dies because it can’t find cuda files.
mpic++ -O2 -funroll-loops -fstrict-aliasing -Wall -W -Wno-uninitialized -DLAMMPS_GZIP -I…/…/lib/reax -I…/…/lib/poems -I…/…/lib/meam -DFFT_FFTW -c force.cpp
In file included from style_pair.h:15:0,
from force.cpp:22:
pair_cg_cmm_coul_cut_cuda.h:33:34: fatal error: pair_cg_cmm_coul_cut.h: No such file or directory
compilation terminated.
make foo >& mk.out
standard unix stuff…
I figured there was a trick…
Ha ha, even make no-all leaves cuda installed. I think I am on to something.
yes. this is one of the issues that i have fixed in LAMMPS-ICMS.
for now do:
cd src
rm *cuda.{cpp,h}
Success!!!
Why am I not seeing any of these issues with
the current version? I can include/exclude the
USER-CUDA package with no problems.
