compilation of lammps with standard packages
              I am trying to compile lammps on cluster. I am using the
steps mentioned in the following link and using operating system as
ubuntu in place of RHEL
http://hpclab.blogspot.com/2010/05/quick-install-guide-for-lammps-on-linux.html
lammps is compiling if i donot include the standard packages like
meam,reax,poem,atc etc. But i want to compile it with all standard
packages.
I have also tried same procedure(changed as per compilers, mpi libray)
on ubuntu 10.04 with GNU compilers,openmpi libray. problem is same
there also.Please suggest me how i may make it installed on both type
of clusters
again, no need to spam the lammps mailing list management or the
mailing list owner's email address with your question. all you to is
irritate people, not get more help.
IoT Laboratory: Quick install guide for LAMMPS on Linux cluster
why do you follow some instructions from some random
person on the net instead of what the lammps manual says?
some of the recommendations at the URL i don't agree with.
packages.
so explain what is the problem!! how should _anybody_ know
what is failing for you when you don't describe it. my crystal
ball is still in repair and they don't seem to be able to fix it.:wink:
of clusters
what do you mean with "both types of clusters"?
i have compiled lammps on a large variety of machines and it
almost always worked very well. prerequisite, however, is that
you know which packages and compilers are installed and how
you use them and then adjust the make file accordingly. almost
any machine used for HPC is a bit different, so there cannot be
the "one configuration that works for all(TM).
packages.
Did you follow the directions in the manual for building with those
packages?
