Hi all,
I am a new user of the EXCITING code. I am trying to compile it. Everything goes smoothly at first but then the compilation stops with an error:
…/…/src/src_inputparser/modinputdom.f90(6): error #7013: This module file was not generated by any release of this compiler. [FOX_DOM]
Use FoX_dom
…/…/src/src_inputparser/modinputdom.f90(10): error #6457: This derived type name has not been declared. [NODE]
Type (Node), Pointer :: doc, inputnp, nullnode, emptynode, dummy
…/…/src/src_inputparser/modinputdom.f90(11): error #6457: This derived type name has not been declared. [DOMCONFIGURATION]
Type (DOMConfiguration), Pointer :: config
…/…/src/src_inputparser/modinputdom.f90(78): error #6457: This derived type name has not been declared. [NODE]
Type (Node), Pointer :: np, unknownnode
…/…/src/src_inputparser/modinputdom.f90(79): error #6457: This derived type name has not been declared. [NODELIST]
Type (NodeList), Pointer :: nl
…/…/src/src_inputparser/modinputdom.f90(80): error #6457: This derived type name has not been declared. [NAMEDNODEMAP]
Makefile.mkmf:1234: recipe for target ‘modinputdom.o’ failed
make[3]: *** [modinputdom.o] Error 1
make[3]: Leaving directory ‘/home/users/eamouj78/Softwares/exciting/build/mpiandsmp’
…/Make.common:78: recipe for target ‘bin’ failed
make[2]: *** [bin] Error 2
make[2]: Leaving directory ‘/home/users/eamouj78/Softwares/exciting/build/mpiandsmp’
Makefile:15: recipe for target ‘all’ failed
make[1]: *** [all] Error 2
make[1]: Leaving directory ‘/home/users/eamouj78/Softwares/exciting/build/mpiandsmp’
Makefile:29: recipe for target ‘mpiandsmp’ failed
make: *** [mpiandsmp] Error 2
Can anyone help me tp resolve this error
