compile single pair style
Hello Users,
If I make modifications to a single pair style and want to recompile, is there a faster was to do it without having to go through the entire process?
thats the whole point of the make file.
Hello Users,
what "entire process" are you talking about?
if you still have the folder where you compiled lammps previously,
then do your modifications, then you just need to type "make ..." with
the same options as before and it should only recompile the necessary
parts (usually a handful of objects). if you did the modifications to
files in a package folder, then you also have to do "make
package-update"
