Dear LAMMPS community,
I tried to figure out what went wrong with my LAMMPS compiling, but could not find out the problem. I’m trying to compile serial version LAMMPS for my small workstation using make serial. It went well up to:
icc -0 -DLAMMPS_GZIP –I…/STUBS –c write_restart.cpp
Then I received long list of error message started with:
Icc -0 -angle_charm.o angle_cosine.o …………………. list of **.o files, very long line, and ended with : undefined reference to ‘operator delete (void)’
Followed by hundreds of lines that always end with:
: undefined reference to ‘*****’
Examples of ***** are:
__gxx_personarity_v0
__cxa_pure_virtual
operator delete
I wish I could’ve cut & paste all errors, but it was just too long. Therefore I summarized it above, and hope it is enough to describe my problem. I appreciate anyone’s suggestion.
Thank you.
Tak
Takahiro Yamada, Ph. D.
Environmental Engineering Group
University of Dayton Research Institute
300 College Park KL102
Dayton, OH 45469
Tel: 937-229-2815
dear tak,
icc -0 -DLAMMPS_GZIP –I../STUBS –c write_restart.cpp
Icc -0 -angle_charm.o angle_cosine.o …………………. list of ***.o files, very
long line, and ended with : undefined reference to ‘operator delete (void*)’
__cxa_pure_virtual
operator delete[](void*)
yes. all of those messages refer to the c++ runtime library.
you are using icc which is the intel C compiler, which will
recognize C++ files if they are named properly to compile
them into C++ object, but it doesn't like with the C++ runtime.
just replace icc with icpc (the intel C++ compiler) and those
linker errors should vanish (unless there are other ones).
