Hi Julian,
Thanks for the quick response! That solved that issue.
However, possibly in relation to the version of gfortran I have installed: GNU Fortran (GCC) 4.4.7 20120313 (Red Hat 4.4.7-3), when running the make file now I have this output:
gfortran -O3 -I… -I/usr/local/include/ -DFLUSH -DNOFOX -c …/m_alamode.F90
…/m_alamode.F90:1207.45:
call execute_command_line(runanphon,wait=.true.,exitstat=status)
1
Error: Keyword argument requires explicit interface for procedure ‘execute_command_line’ at (1)
…/m_alamode.F90:1227.45:
1
…/m_alamode.F90:1354.45:
1
…/m_alamode.F90:337.42:
call execute_command_line(runalm,wait=.true.,exitstat=status)
1
…/m_alamode.F90:936.44:
1
…/m_alamode.F90:1026.44:
1
make: *** [m_alamode.o] Error 1
mv: cannot stat `gulp’: No such file or directory
It looks to me like an issue with compiler not understanding some new code features as you said. However, I don’t code in Fortran unfortunately, so I am not entirely sure what the error means.
If you know of a way around this issue that would be great! Or if it would be more expedient to download an older version of GULP I may just do that. Unfortunately, updating gfortran is not really possible at the moment, as I am not root on the server and the server manager is on holiday.
I believe the parallel features of GULP are only on the newer versions however, so perhaps the use of an older version would still not be useful?
Thanks again,
Connor
