Yes I need to fix the thread count for Kokkos at the bottom of the log file.
You may already know this but when you compare Kokkos to the USER-OMP package on CPUs, you will probably get better performance if you use a half neighbor list with newton on. From the command line you can use “-pk kokkos neigh half newton on”. Also, using the “comm no” option is sometimes better for CPUs as well.
Regards,
Stan
