Hello!
I'm trying to compile LAMMPS with OpenMPI-1.4.2, however I have not
been able to get a working executable, the result is always that it
fails with a segfault. The executable compiled with Makefile.serial
works as intended.
Makefile and output is below. There is something that I'm not seeing
here, but I don't knwo what is is. Any help would be appreciated.
Thomas
[email protected]... ~/lammps-9Dec11/src $ cat MAKE/Makefile.michelin
CC = mpiCC
CCFLAGS = -O
DEPFLAGS = -M
LINK = mpiCC
LINKFLAGS = -O
MPI_INC =
MPI_PATH =
MPI_LIB =
LIB =
[email protected]... ~ $ mpirun -np 2 lmp_serial -help
LAMMPS (9 Dec 2011)
List of style options included in this executable:
[email protected]... ~ $ mpirun -np 1 lmp_michelin -help
[michelin:26163] *** Process received signal ***
[michelin:26163] Signal: Segmentation fault (11)
[michelin:26163] Signal code: Invalid permissions (2)
[michelin:26163] Failing at address: 0x7f327713b385
[michelin:26163] [ 0] /lib64/libpthread.so.0(+0x10310) [0x7f3276ba9310]
[michelin:26163] [ 1]
lmp_michelin(_ZN9LAMMPS_NS8Universe9add_worldEPc+0x138) [0x547054]
[michelin:26163] [ 2]
lmp_michelin(_ZN9LAMMPS_NS6LAMMPSC1EiPPcP19ompi_communicator_t+0x5db)
[0x5f6a41]
[michelin:26163] [ 3] lmp_michelin(main+0x3d) [0x5e6845]
[michelin:26163] [ 4] /lib64/libc.so.6(__libc_start_main+0xfd) [0x7f327511de9d]
[michelin:26163] [ 5] lmp_michelin() [0x473219]
[michelin:26163] *** End of error message ***
Hello!
works as intended.
can you compile and run other MPI programs
with the same OpenMPI installation?
the error looks as if it originates from your MPI installation.
Hello!
The charm test suite that comes with NAMD 2.8 finishes without complaints.
[email protected]... ~/NAMD_2.8_Source/charm-6.3.2/tests/charm++/megatest $
mpirun -np 20 -H node1,node2,node3,node4,node5
~/NAMD_2.8_Source/charm-6.3.2/tests/charm++/megatest/pgm
All tests completed, exiting
End of program
I had considered that, but how do I tell?
Thomas
Hello!
End of program
the next best thing that you can try is to compile
with debug info (add -g to CCFLAGS and LINKFLAGS)
and run the executable through a debugger:
mpirun -np 1 gdb lmp_michelin
run -help
and then inspect the stack frame and
see which call exactly crashes where.
cheers,
Hello!
This is true, in a way. The executable was compiled with option
LMP_INC = -DLAMMPS_MEMALIGN, and openmpi knows about malloc(), but not
about posix_memalign().
Ouch. Without that option, MPI runs go perfectly fine. Problem solved.
sorry, but this doesn't make much sense.
what is the relation between MPI and malloc()/posix_memalign()?
i've been using posix_memalign() for ages *with* OpenMPI for years
now and on different platforms and with different versions of OpenMPI.
there must be something else that was miscompiled
and got cleaned out when you change the make file settings.
Hello!
I was under the impression that OpenMPI intercepts calls to malloc(),
but not to posix_memalign()?
Whatever the cause for this bug is, it is reproducible. Segfault for
-DLAMMPS_MEMALIGN, no segfault without that definition.
Thomas
Hello!
that was changed many years ago. all openmpi does is
replace the malloc with its own for allocation of pinned
memory, so it is not returned to the kernel for performance
reasons. OpenMPI or any other MPI library has no job to
interfere with memory allocations in an incompatible way.
it certainly is not a bug in LAMMPS.
more likely is a problem with the setup
of your cluster.
