Compiling on Blue-Gene/L
I’m trying to compile LAMMPS on a BlueGene/L system (https://www.scorec.rpi.edu/wiki/SUR_Blue_Gene).
I am facing the following problem after the compilation ends (seems to) successfully.
…(blah blah)
respa.o run.o set.o special.o thermo.o timer.o universe.o update.o variable.o velocity.o verlet.o write_restart.o
-lmpich.rts -lmsglayer.rts -lrts.rts -ldevices.rts -lm -o …/lmp_sdsc1
size …/lmp_sdsc1
text data bss dec hex filename
4585066 502832 117468 5205366 4f6d76 …/lmp_sdsc1
make[1]: Leaving directory `/gpfs/gpfs0/home/pala2/lammps-9Nov11/src/Obj_sdsc1’
pala2@…3112…:~/lammps-9Nov11/src> ./lmp_sdsc1
BGLPersonality version mismatch.
Aborted
I’m at a loss at understanding the root of the problem. I thought compiling the FFTW2 libraries with the same compiler as CC would solve the problem but it did not.
Would any of you guys be kind enough to give me a lead?
The make file is given below.
Thank you,
Anirban
**** Makefile.sdsc1 *****
sdsc = SDSC BG/L machine, xlC, native MPI, FFTW
SHELL = /bin/sh
.SUFFIXES: .cpp .u
compiler/linker settings
specify flags and libraries needed for your compiler
CC = /opt/ibmcmp/vacpp/bg/8.0/bin/blrts_xlC
CCFLAGS = -I/bgl/BlueLight/ppcfloor/bglsys/include
-O3 -qstrict
DEPFLAGS = -M
LINK = /opt/ibmcmp/vacpp/bg/8.0/bin/blrts_xlC
LINKFLAGS = -O3 -qstrict
-L/bgl/BlueLight/ppcfloor/bglsys/lib
-L/opt/ibmcmp/xlf/bg/10.1/blrts_lib
-L/opt/ibmcmp/vacpp/bg/8.0/blrts_lib
LIB = -lm
ARCHIVE = ar
ARFLAGS = -rc
SIZE = size
LAMMPS-specific settings
specify settings for LAMMPS features you will use
if you change any -D setting, do full re-compile after “make clean”
LAMMPS ifdef settings, OPTIONAL
see possible settings in doc/Section_start.html#2_2 (step 4)
LMP_INC = -DLAMMPS_GZIP -DLAMMPS_XDR
MPI library, REQUIRED
see discussion in doc/Section_start.html#2_2 (step 5)
can point to dummy MPI library in src/STUBS as in Makefile.serial
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
MPI_INC = -DMPICH_SKIP_MPICXX
MPI_PATH =
MPI_LIB = -lmpich.rts -lmsglayer.rts -lrts.rts -ldevices.rts
FFT library, OPTIONAL
see discussion in doc/Section_start.html#2_2 (step 6)
can be left blank to use provided KISS FFT library
INC = -DFFT setting, e.g. -DFFT_FFTW, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
FFT_INC =
FFT_INC =
FFT_LIB =
#FFT_INC = -DFFT_FFTW2 -I/gpfs/gpfs0/home/pala2/fftw2-xlC/include
#FFT_PATH = -L/gpfs/gpfs0/home/pala2/fftw2-xlC/lib
#FFT_LIB = -lfftw
JPEG library, OPTIONAL
see discussion in doc/Section_start.html#2_2 (step 7)
only needed if -DLAMMPS_JPEG listed with LMP_INC
INC = path for jpeglib.h
PATH = path for JPEG library
LIB = name of JPEG library
JPG_INC =
JPG_PATH =
JPG_LIB =
build rules and dependencies
no need to edit this section
include Makefile.package.settings
EXTRA_INC = (LMP_INC) (PKG_INC) (MPI_INC) (FFT_INC) (JPG_INC) (PKG_SYSINC)
EXTRA_PATH = (PKG_PATH) (MPI_PATH) (FFT_PATH) (JPG_PATH) (PKG_SYSPATH) EXTRA_LIB = (PKG_LIB) (MPI_LIB) (FFT_LIB) (JPG_LIB) (PKG_SYSLIB)
Link target
(EXE): (OBJ)
(LINK) (LINKFLAGS) (EXTRA_PATH) (OBJ) (EXTRA_LIB) (LIB) -o (EXE) (SIZE) $(EXE)
Library target
lib: (OBJ) (ARCHIVE) (ARFLAGS) (EXE) $(OBJ)
Compilation rules
.o:.cpp
(CC) (CCFLAGS) (EXTRA_INC) -c <
.u:.cpp
(CC) (CCFLAGS) (EXTRA_INC) (DEPFLAGS) -c $<
Individual dependencies
DEPENDS = (OBJ:.o=.d) sinclude (DEPENDS)
…(blah blah)
size …/lmp_sdsc1
Aborted
The root of the problem is your lack of knowledge about the blue gene architecture. It has a different type of architecture and operating system on the login node and the compute node. Your compiler is a cross compiler and thus the resulting binaries cannot be run on the node where they have
…(blah blah)
size …/lmp_sdsc1
Aborted
been compiled. Talk to a local person that knows the hardware and read the documentation to understand what you are doing.
Axel
