Is there a known issue with compiling OpenKIM 1.2.2 on RedHat 6 and similar distributions? Specifically, if I run ‘make examples’ (which seems to work), then ‘make’, make segfaults. Interestingly, if I run ‘make’ without having run ‘make examples’, make does not segfault. I’ve tried GCC 4.4 and 4.7.3 with similar results. I’ve also tried on a freshly-installed CentOS 6.4 system to no avail.
Output:
make examples
Makefile:42: Makefile.ModelsList: No such file or directory
Makefile:42: Makefile.ModelDriversList: No such file or directory
Makefile:42: Makefile.TestsList: No such file or directory
Creating… Makefile.TestsList.
Creating… Makefile.ModelDriversList.
Creating… Makefile.ModelsList.
Creating… KIM_Config file… KIM_API/Makefile.KIM_Config.
Creating… KIM_Config file… MODEL_DRIVERS/Makefile.KIM_Config.
Creating… KIM_Config file… MODELS/Makefile.KIM_Config.
Creating… KIM_Config file… TESTS/Makefile.KIM_Config.
- installing… ex_model_driver_P_LJ … copied to /software/OpenKIM/openkim-api-v1.2.2/MODEL_DRIVERS
- installing… ex_model_driver_P_Morse … copied to /software/OpenKIM/openkim-api-v1.2.2/MODEL_DRIVERS
- installing… EXAMPLES.README … copied to /software/OpenKIM/openkim-api-v1.2.2/MODEL_DRIVERS
- installing… ex_model_Al_PF_ErcolessiAdams … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_LJ … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_MLJ_C … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_MLJ_CLUSTER_C … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_MLJ_CLUSTER_F90 … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_MLJ_F90 … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_MLJ_MI_OPBC_H_F … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_MLJ_NEIGH_PURE_H_F … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_MLJ_NEIGH_RVEC_F … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ar_P_Morse … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_ArNe_P_MLJ_NEIGH_RVEC_F … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Cu_PF_Johnson … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ne_P_fastLJ … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ne_P_LJ … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ne_P_LJ_NEIGH_PURE_H … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ne_P_MLJ_NEIGH_RVEC_H … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_model_Ne_P_Morse … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… EXAMPLES.README … copied to /software/OpenKIM/openkim-api-v1.2.2/MODELS
- installing… ex_test_Al_FCCcohesive_MI_OPBC … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Al_free_cluster … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_FCCcohesive_MI_OPBC … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_FCCcohesive_NEIGH_PURE … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_FCCcohesive_NEIGH_RVEC … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_FCCcohesiveCutoff_NEIGH_RVEC … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_free_cluster … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_free_cluster_CLUSTER_C … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_free_cluster_CLUSTER_F90 … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_free_cluster_CLUSTER_memory_F90 … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ar_multiple_models … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_ArNe_B2cohesive_NEIGH_RVEC … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Cu_free_cluster … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ne_free_cluster … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ne_free_cluster_SI … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… ex_test_Ne_free_cluster_stiff … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… EXAMPLES.README … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… run_all_ex_tests … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… run_forces_numer_deriv_for_all_models … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… vc_config_ener_forces … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… vc_forces_delta … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
- installing… vc_forces_numer_deriv … copied to /software/OpenKIM/openkim-api-v1.2.2/TESTS
make
*** glibc detected *** make: malloc(): memory corruption (fast): 0x000000000063dbd0 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x76126)[0x7ffff7ac0126]
/lib64/libc.so.6(+0x79edf)[0x7ffff7ac3edf]
/lib64/libc.so.6(__libc_malloc+0x71)[0x7ffff7ac4951]
make[0x4120f8]
make[0x412229]
make[0x4136fe]
make[0x406997]
make[0x407324]
make[0x40761e]
make[0x410e79]
/lib64/libc.so.6(__libc_start_main+0xfd)[0x7ffff7a68cdd]
make[0x402429]
======= Memory map: ========
00400000-00428000 r-xp 00000000 08:02 419590 /usr/bin/make
00628000-0062a000 rw-p 00028000 08:02 419590 /usr/bin/make
0062a000-0066c000 rw-p 00000000 00:00 0 [heap]
7ffff19a4000-7ffff19b9000 r-xp 00000000 00:13 926648659 /panfs/pas14/apps/LINUX/gcc/4.7.3/lib64/libgcc_s.so.1
7ffff19b9000-7ffff1bb8000 —p 00015000 00:13 926648659 /panfs/pas14/apps/LINUX/gcc/4.7.3/lib64/libgcc_s.so.1
7ffff1bb8000-7ffff1bb9000 rw-p 00014000 00:13 926648659 /panfs/pas14/apps/LINUX/gcc/4.7.3/lib64/libgcc_s.so.1
7ffff1bb9000-7ffff7a4a000 r–p 00000000 08:02 405945 /usr/lib/locale/locale-archive
7ffff7a4a000-7ffff7bd4000 r-xp 00000000 08:02 133667 /lib64/libc-2.12.so
7ffff7bd4000-7ffff7dd3000 —p 0018a000 08:02 133667 /lib64/libc-2.12.so
7ffff7dd3000-7ffff7dd7000 r–p 00189000 08:02 133667 /lib64/libc-2.12.so
7ffff7dd7000-7ffff7dd8000 rw-p 0018d000 08:02 133667 /lib64/libc-2.12.so
7ffff7dd8000-7ffff7ddd000 rw-p 00000000 00:00 0
7ffff7ddd000-7ffff7dfd000 r-xp 00000000 08:02 133663 /lib64/ld-2.12.so
7ffff7fe1000-7ffff7fe4000 rw-p 00000000 00:00 0
7ffff7ff9000-7ffff7ffb000 rw-p 00000000 00:00 0
7ffff7ffb000-7ffff7ffc000 r-xp 00000000 00:00 0 [vdso]
7ffff7ffc000-7ffff7ffd000 r–p 0001f000 08:02 133663 /lib64/ld-2.12.so
7ffff7ffd000-7ffff7ffe000 rw-p 00020000 08:02 133663 /lib64/ld-2.12.so
7ffff7ffe000-7ffff7fff000 rw-p 00000000 00:00 0
7ffffffea000-7ffffffff000 rw-p 00000000 00:00 0 [stack]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
Aborted (core dumped)
