Composition and formation enthalpy of random alloy?
Hello Dr Axel and atat users,
I’m a newbie with alloy and ATAT. I just spent a couple of days to understand how to use ATAT as well as theory of cluster expansion and sqs method because my current project concerns these topics. Our concern is a new binary alloy. From XRD, we knew that is random alloy with fcc lattice, however, composition is not actually clear. As far I know, MAPS can make a convex hull for ordered alloys with determined type of crystal, but is there anyway to have a convex hull including random alloys?
For formation enthalpy of radom alloy, it looks like one of the best approach is using SQS method. For some cases of well-known alloy, the differences between theory and experiment are about 1kJ/mol (~10meV/atom). However, for new random alloy, is it safe to use this method? or there is other method implemented in ATAT can improve final results.
Thank you very much in advance.
When looking at a disordered solution, you should not look at the convex hull of the energies. Since disordered solution occur at high temperature, you have to include a configurational entropy term at least: the simplest way to do this is to add sum_i x_i ln(x_i) (where x_i are compositions) to your SQS energies.
Even better would be to fit a polynomial through your sqs energies. The sqs2tdb automates a lot of this and produce a working .tdb file for use with thermocalc, for instance.
