Dear Lammps users,
I want to perform a compression test in z-direction, but I want to have non-periodic bc in z-direction. That’s why I decided to use fix wall/lj126 to compress the system. I want the simulation box to change in x and y direction, so I couple it with fix npt in x and y direction. But unlike what I expected after a few compression steps it gives the following error.
The box size in x and y direction only fluctuates, and the change is not comparable with the compression. I even tried using NVT and it again did not change box size in x and y directions. Attachment is the input file, the log file for both using NPT(in x and y direction) and NVT. I was wondering how should I solve this issue to observe system size change in x and y directions.
Sepideh
Step KinEng PotEng Press Lx Ly Lz Pxx Pyy Pzz
0 7.6392746 -650.50999 -9413.5585 12.18 12.18 28.42 -11967.777 -11960.251 -4312.6478
1000 7.820194 -643.40206 6237.5802 12.085471 12.127597 28.42 4706.2858 3346.1076 10660.347
2000 7.7440042 -643.04421 -803.09661 12.139826 12.170599 28.42 -2045.5918 -2920.4301 2556.732
3000 7.8925054 -643.20869 786.7776 12.11608 12.161241 28.42 378.32171 -1148.0517 3130.0628
4000 7.8157654 -643.08568 3413.9904 12.079667 12.105849 28.42 2538.9482 2455.7125 5247.3106
5000 7.6975426 -643.02383 -2151.9124 12.118654 12.159658 28.42 -3151.385 -3679.3052 374.95305
6000 8.0299079 -643.30911 2671.2928 12.108236 12.071537 28.42 1328.6455 2643.7503 4041.4827
7000 7.7985099 -643.02726 -2978.9436 12.143986 12.122379 28.42 -3934.7183 -4117.4212 -884.69133
8000 7.746233 -643.06364 1439.1423 12.087154 12.071605 28.42 831.18484 1956.5382 1529.7038
9000 7.6897774 -642.96316 36.898684 12.098967 12.07307 28.42 58.872743 244.63712 -192.81381
10000 7.9710423 -643.26397 -2003.4959 12.109156 12.066954 28.42 -2424.4851 -1087.6126 -2498.39
11000 7.9182251 -643.21072 -1137.2981 12.087996 12.061811 28.42 -184.46689 -744.8084 -2482.619
12000 7.4211633 -642.63787 -582.1693 12.080111 12.053602 28.42 -246.20735 100.06814 -1600.3687
13000 7.3892051 -642.6271 697.17116 12.082088 12.059888 28.42 1411.9426 430.38346 249.18741
14000 7.061011 -642.39836 -1682.3495 12.093979 12.065977 28.42 -1559.2894 -1380.186 -2107.573
ERROR: Lost atoms: original 198 current 180 (src/thermo.cpp:441)
Last command: run ${step}
compression_step.lammpstrj (122 KB)
test.in (2.56 KB)
log-nvt.log (7.17 KB)
log-npt.log (7.17 KB)
