compression test
Hello
I am a new user of LAMMPS and I want to do a compression test.
I did a compression model but the results seems weird. The stress always increase during the compression test. It never decreases and I know it’s wrong.
I send my model, can you say what are my errors?
Thank you and have a nice day!
Mai Thi
atom_style atomic
neighbor 0.3 bin
neigh_modify delay 5
#create geometry
lattice bcc 3.304
region box block 0 1 0 1 0 1
create_box 1 box
create_atoms 1 box
#Interatomic potentials
pair_style eam/alloy
pair_coeff * * Ta.txt Ta
#equilibrate
velocity all create 300.0 100 rot yes dist gaussian
fix 1 all npt temp 300.0 300.0 100.0 iso 0.0 0.0 1000.0
fix 2 all temp/rescale 1 300.0 300.0 0.001 1.0
thermo 200
thermo_style custom step lx ly lz pxx pyy pzz temp
timestep 0.005
run 2000
unfix 1
unfix 2
variable l equal lx
variable l0 equal $l
#compression
reset_timestep 0
fix 1 all nvt temp 300.0 300.0 100.0
fix 3 all deform 1 x erate 0.005 units box remap x
variable strain equal “(lx-v_l0)/v_l0”
#For units metal pressure is 1 (bars) = 1/10000(GPa)
variable p1 equal “-pzz/10000”
#For units metal distance is 1 (Angstrom) = 0.0000001 (cm)
variable l1 equal lx*0.0000001
fix results all print 500 “{p1} {strain}” file results.txt screen no title “stress strain”
thermo 200
thermo_style custom step v_strain temp v_l1 v_p1 press
#dump 1 all xyz 100 dump.file.xyz
dump 2 all image 100 image.*.jpg type type zoom 1.6 adiam 1.5
#dump_modify 2 backcolor white
#dump_modify 2 boxcolor black
run 40000
Hello
For starters, please examine the lammps log file carefully and correct the enormous mistakes lammps is warning you about.
Axel
