Compute center of a angle when it passes through the boundary
When I compute the center of a angle as below:
for (n = 0; n < nanglelist; n++)
i1 = anglelist[n][0];
i2 = anglelist[n][1];
i3 = anglelist[n][2];
type = anglelist[n][3];
// find the center-of-mass
tcx = (x[i1][0] + x[i2][0] + x[i3][0])/3.0;
tcy = (x[i1][1] + x[i2][1] + x[i3][1])/3.0;
tcz = (x[i1][2] + x[i2][2] + x[i3][2])/3.0;
it has no problem at local domain, but if some of the atoms belong to one angle pass through the boundary, the compute is incorrect.
Also, I compute some vectors like this
a21x = x[i2][0] - x[i1][0];
a21y = x[i2][1] - x[i1][1];
a21z = x[i2][2] - x[i1][2];
If this is correct when the bond with atom i1 and atom i2 pass across the boundary.
Lynn H. Ye
I think you are asking why code you wrote is incorrect?
I can’t tell you the reason, but if you are writing your
own angle style and do things like the other
angle styles, such as harmonic, do them, then
you won’t have this problem. The 3 atoms
that are referenced in the anglelist are setup by
the neighbor list build so that they are 3 nearby
atoms. That means if the atom straddles the box
boundary, one or more of the atoms may be ghost
atoms, with coords outside the box. So there is
no issue with computing a COM or distances between
any pair of the 3 atoms.
