I am trying to calculate the com of two molecules making up a complex.
However the command
compute 1 all com/molecule
fails with the error message ‘Segmentation fault’.
The number of atoms in the complex are 43,000.
Did I forget anything or are there any limitations for this command?
If there are any, how can I circumvent them?
However the command
fails with the error message 'Segmentation fault'.
how should we know. most commands in an input script
have to be seen in the context of the others and the system
data that you are using.
a segmentation fault can mean several things.
- you are running out of address space ("memory")
- you are doing something unusual or unexpected in your input
- you have found a bug in lammps
in any case, you need to provide the following information:
- what version of lammps do you use? if it is not the latest
version. please download/compile that one and see whether
the problem goes away. perhaps you found a bug that has
already been fixed.
- what platform are you running on? are you running in parallel
or serial?
- provide a minimal input (and data file) that will reproduce
this your problem. this makes it easy for experienced people
to confirm the problem and then suggest a solution.
people here are scientists, not psychics. we use facts and
logic to sort out a problem, not a crystal ball.
