compute group/group in a different model
Hi!
It’s my first time to write my question to you with this method. I don’t know if the method is right. And if there is any trouble with you, I am sorry.
My problem is about a force of two group. In simple terms, my model is that the middle layer of polymer chains is pressed with two fcc cryatal. What I need to calculate is the pressure between layer and the upper crystal. The units id LJ,and the command is compute group/group. And I found the force is equal with different size of model in a same load(the load way via the command of “addforce”). In other words, The force output by thermo_style with ADDFORCE command at the same load should increase proportionally. However ,the result is identical.
And then I read the manual of units and group/group command!
The manual say that force in three direction are “extensive”, and extensive quantities are output by SUM/ATOM. What? This is contrary to the group/group command/
In the next I tested the easy model with different size. And I got the same conclusion.
And can you tell me where I have wrong?
The following is my in.test.
units lj
atom_style bond
boundary p p s
special_bonds fene
read_data 30.softall
neighbor 0.4 bin
neigh_modify every 1 delay 1
bond_style fene
bond_coeff 1 30.0 1.5 1.0 1.0
pair_style hybrid lj/cut 2.0
pair_modify shift yes
pair_coeff 1 1 lj/cut 1.0 1.0
pair_coeff 1 2 lj/cut 1.0 1.0
pair_coeff 1 3 lj/cut 1.0 1.0
pair_coeff 2 2 lj/cut 1.0 1.0
pair_coeff 3 3 lj/cut 1.0 1.0
pair_coeff 2 3 lj/cut 1.0 1.0
pair_coeff * 4 none
atom regions
region lo-fixed block INF INF INF INF INF -11.937
region hi-fixed block INF INF INF INF 11.937 INF
group lo region lo-fixed
group hi region hi-fixed
group boundary union lo hi
group mobile subtract all boundary
group up type 2
group chain type 1
group down type 3
group gvv type 4
group bcchi subtract up hi
group bcclo subtract down lo
group slide subtract all lo
If you are using LJ units then the thermo output will
divide extensive quantities by N (by default) See the doc
page for the units and thermo_style and thermo_modify commands.
