Hi, Steve, last time I confused you. The components are not nearly zeros. Also, what I am trying to do is to check the net flux amount out of the slab by this command, is this possible? Maybe ave/time command to save the data at this point is not working at such case.
nobody can say anything meaningful without having detailed information.
just quoting a few lines of LAMMPS input without knowing the exact
setup, and process of equilibration and whatever else you are doing in
your simulation, is not telling much. there have *lots* of things that
can go wrong and taint your results that have nothing to do with the
commands you have quoted.
LAMMPS commands do what their documentation says it does. if you can
construct a verifiable test case that shows a discrepancy between the
documentation and the implementation, people will look at it. there is
no value in speculation like you are doing it.
