It seems that the total pressure and energy are always calculated on
timestep 0, even if they are not needed/never called for in the input
script. Is there a way to change this?
Stan
Stan
It seems that any pre-defined compute (total energy, pressure) and any
user-defined compute in the input script is calculated on timestep 0,
even if it is never used... It would be nice to check and see if a
compute is ever used, and if it is not, don't calculate it on timestep
0.
Stan
I think that the "run 0" trick is the only way to obtain thermodynamic
properties before the start of the simulation (and this is a VERY
useful trick). Why would you want to eliminate it? I mean, this
calculation is not expensive because it happens only once AND is very
useful....
Rodrigo
I am trying to get accurate timings of a new method with and without
pressure/energy turned on. I'm only using a few timesteps, and even if
I turn off the pressure/energy in the input script, it is still
calculated on timestep 0, which influences the results. I have to
manually set the eflag and vflag variables in the codes and recompile
to get accurate run times. I don't want to eliminate the "run 0"
trick if it is actually needed/called for in the input script, but
right now the total pressure/energy are still calculated on timestep 0
even there is *nothing* related to them in the input script...
You can't eliminate it on the very first run.
But you can on subsequent runs, using
the "pre no" option for the run command.
