Hi all,
I am trying to compute pressure and I need output after every timestep so that it will enable me to plot the values. But in my log file, I receive only 1 set of values after the complete simulation is over. I would like to hear some suggestions as to what I can do. Thanks in advance.
Regards,
Muthukumar
I should have made it more clear. I have read the manuals and tried to output the global values from ‘compute pressure’ using ‘thermo_style’ command. Yet it returns only one set of values after the simulation is completed though i tried ‘dump’ command to output other values like atom position etc. which it rightly does every N steps that I had requested for. Shouldn’t thermo_style return pressure values after every N steps as well?
Muthukumar
have you tried http://lammps.sandia.gov/doc/thermo.html ?..
output the global values from 'compute pressure' using 'thermo_style'
completed
what did u specify in "thermo N" command??
though i tried 'dump' command to output other values like atom position
Shouldn't thermo_style return pressure values after every N steps as well?
Yes, it should, and it does.!!
Sagar
Thanks a lot, now it works fine.
