I would like to compute the radial distribution function (RDF) between similar molecules of higher alkanes such as aliphatic n-C22.
For example, to represent the center of mass for this hydrocarbon, I would like to specify the 11th carbon on this chain as the atom type for the RDF calculation. My problem is all the Carbon atoms in n-C22 are of the same atom type. Is there a way to compute RDF between certain atoms on a chain of atoms with the same atom type?
J. Berry
the simplest approach would be to simply give the 11th carbon a
different atom type number, but use the same parameters as for the
other carbons of the same type.
