Dear all
The forth column of output files when we use compute RDF is the coordination number.
I calculated the area under the RDF curve using Trapezoidal approximation
method. The value is too different from that I see in the forth column even if the bin’s size is 1 Angstrom.
I would appreciate if I have your advice.
Dear all
number.
if the bin's size is 1 Angstrom.
yes, because what you did is not correct.
What should I do?
What should I do?
ever tried using google? or look on wikipedia?
https://en.wikipedia.org/wiki/Coordination_number#Usage_in_quasicrystal.2C_liquid_and_other_disordered_systems
what LAMMPS provides is the integral from 0 to r, of course.
