Hi all,
I have a question about computing the stress. I wrote in my code to compute the pressure of entire system, and also I wrote "dump’ to have an output for stress, but the problem is that lammps does not give me any output file for stress. I s there any problem in my code. I appreciate if you could help me to find an approach for this problem.
Elham
#set dimension and boundry condition
#set units type,atom type and neigborhood
atom_style atomic
##neigh_modify every 1
#create big box
lattice fcc 3.52
region big sphere 0.0 0.0 0.0 20.0 units lattice
create_box 1 big
#create main atoms
region eli sphere 0.0 0.0 0.0 25.0 side in
create_atoms 1 region eli
group e1 region eli
#create second atoms
region hap sphere 55.5 0.0 0.0 30.0 side in
create_atoms 1 region hap
group e2 region hap
#create third atoms
region cap sphere 0.0 65.0 0.0 35.0 side in
create_atoms 1 region cap
group e3 region cap
#create forth atoms
region mos sphere 75.5 65.0 0.0 40.0 side in
create_atoms 1 region mos
group e4 region mos
#add all the nanoparticles
group all union e1 e2 e3 e4
#set the mass of atoms
mass 1 58.69
#set the velocity of atoms
velocity all create 600.0 4928459 rot yes mom yes
#define the eam
pair_style eam
pair_coeff * * Ni_u3.eam
##pair_coeff 1 1 0.7 2.517 ##For LJ
#Specify build neighborlist, use cutoff+0.3 A
neighbor 2 bin
#Frequency to rebuild neighborlist
fix pip all nvt temp 600 600 0.0050
minimize 1.0e-6 1.0e-8 1000 1000
#set timestep
timestep 0.0005 #0.5 femtosecond
compute Fall all pressure NULL pair bond
#specify values to show in run
thermo 1000
thermo_style custom step temp pe ke etotal
dump Nidump all atom 1000 sphere-temp-600-4diff-nps.dump
dump Ni all local c_nan 1000 4diff-nps-sphere-temp600.stress
###dump 1 all custom 1 sphere11_temp1000.txt id type x y z
#specify the method of calculation
run 100000
