compute temp/com
few days ago I saw a post regarding shock simulation and comments by Ray Shan, oscar G,…i’m really interested to know that, is there any fix to compute temp/com like value spatialy averaged by using ave/spatial ? I checked the documentation and learn that temp/com compute global basis not per atom basis, so how can i get values spatially averaged.
like temperature, is it not so that such com’s transnational kinetic energy ( momentum mirror method in shock generation) also have effect on pressure and kinetic energy ?
How can I compute those after subtracting com velocity ?
Hi Paul,
Shan, oscar G,..i'm really interested to know that, is there any fix to
You may define regions, apply a compute temp/com to each of these
regions, then use fix ave/spatial to obtain each region's averaged
temp with V_com removed.
like temperature, is it not so that such com's transnational kinetic energy
Yes, P and KE are affected by the removal of V_com. You may calculate
P and KE for each regions after subtracting V_com, which I post
process.
Hi Paul,
regions, then use fix ave/spatial to obtain each region’s averaged
compute temp/com produce a global scalar (the temperature) and a global vector of length 6 (KE tensor) , then how can I use ave/spatial to average out spatially, where ave/spatial required a compute that output per-atom basis ?
process.
for KE if I set calculation as E= 3/2 KT, where this T is after removal of V_com and computed by temp/com then should I get the global KE ? How can i make it spatially averaged ?
could you give any clue, how can I post-process to get P, KE after removal of V_com ?
> not
basis ?
by velocity command with style "set" and keyword "sum yes"? I am not
sure if this will work, but you can apply the above command to have
V_com removed from each per-atom velocity for each region.
> energy
> pressure
process.
of V_com ?
KE is the easy one: just subtract V_com from each per-atom V, then use
the energy-velocity relation.
P is only a little more complicated. A volume V being pressed by a
piston has P*V work being done to the system. Using the work-energy
principle, you can estimate P from per-atom velocities, while these
velocities also have V_com subtracted. You can estimate P for each
region, given V for each region is defined.
Cheers,
Ray
not
basis ?
by velocity command with style “set” and keyword “sum yes”? I am not
which command you are suggesting to compute per atom velocity after subtracting V_com ?
Do you suggest to use different style and keyword for that ? please mention which one ?
yes i am using “set” & “sum” to set com velocity , and temp/com to get global temperature.
energy
pressure
process.
of V_com ?
I’m trying to look with this.
Thanks for feedback.
subtracting V_com ?
i don't understand the fuss about "computing" velocities. velocities
are required per atom properties and thus are immediately available
for atom style variables. nothing needs to be computed since you
cannot do MD without them.
subtracting V_com ?
i don’t understand the fuss about “computing” velocities. velocities
i’m setting additional velocity in each atom by velocity command with style “set” and keyword “sum yes” to move my system towards a particular direction ( for shock generation ) i.e. towards the mirror (fix wall/reflect) ; now my sample have some transnational kinetic energy of center-of-mass. So if I apply atom style variable vx, vy or vz, certainly it will compute per-atom velocity but some component due to the com velocity will be there included. Now I need to have the per-atom velocity after subtracting the c-o-m vel component. How can I get this per atom velocity ?
Swain Paul
> subtracting V_com ?
i'm setting additional velocity in each atom by velocity command with style
"set" and keyword "sum yes" to move my system towards a particular direction
exactly how you described it. subtract the COM velocity and then you have it.
subtracting V_com ?
I have computed “temp” using “thermo_style” and simultaneously I have computed “temp/com”, to see the difference between vel and vel after subtracting v_com, I get result 5100K and 58K for a given instantaneous timestep. So surely the v_com have effect on those variables which I need to have, isn’t it ?
Once I get the vel after subtracting v_com, i can post process to get the required variables like KE, pressure etc.
Am I missing something ?
>> >> not
>> > subtracting V_com ?
> style
> direction
> now my
> I
> per-atom
> included.
it.
I have computed "temp" using "thermo_style" and simultaneously I have
computed "temp/com", to see the difference between vel and vel after
have, isn't it ?
sure. but why do you need to compute the temperature to access the velocities?
obviously. i don't understand what you are asking. all the information
you are asking for is readily available. what is so difficult in doing
something like this?
variable vxu atom "vx-gmask(mygroup)*vcm(mygroup,x)"
not
subtracting V_com ?
style
direction
now my
I
per-atom
included.
it.
have, isn’t it ?
not like that I need T, P, KE etc per atom basis to do ave/spatial further. For that I need to have per atom velocity after that I formulate all the required variables. This temp/com is just to get global temperature after subtracting v_com, not to get velocity using this.
obviously. i don’t understand what you are asking. all the information
variable vxu atom “vx-gmask(mygroup)*vcm(mygroup,x)”
is v_cm = center of mass of my group or vcm = center of mass velocity ? what this gmask(mygroup) ?
not
subtracting V_com ?
style
direction
now my
I
per-atom
included.
it.
have, isn’t it ?
sorry I got gmask as a special variable, documented in lammps manual. But if vcm = velocity of center of mass, how can I get ?
it always helps to have a look at the documentation. you can start here:
http://lammps.sandia.gov/doc/variable.html
You can define an atom-style variable that calculates
the KE (i.e. temperature) of each atom, and subtracts
off the COM velocity in the calculation, by using the
variable group commands. You can then use fix ave/spatial
with that variable.
