When submitting jobs in our local cluster, I only execute a command $ qsub parallel.sh and the job already goes into our queue. I’m having problems incorporating FireWorks into this. I have reached the tutorial about launching rockets through a queue.
This is what returned after $ qlaunch singleshot
Database at /data_piglet/lansan/atomate/config/FW_config.yaml is getting selected.
Found many potential paths for LAUNCHPAD_LOC: [’/data_piglet/lansan/atomate/config/my_launchpad.yaml’, ‘/data_piglet/lansan/atomate/fw_tutorials/queue/queue_tests/my_launchpad.yaml’]
Choosing as default: /data_piglet/lansan/atomate/config/my_launchpad.yaml
Found many potential paths for FWORKER_LOC: [’/data_piglet/lansan/atomate/config/my_fworker.yaml’, ‘/data_piglet/lansan/atomate/fw_tutorials/queue/queue_tests/my_fworker.yaml’]
Choosing as default: /data_piglet/lansan/atomate/config/my_fworker.yaml
Found many potential paths for QUEUEADAPTER_LOC: [’/data_piglet/lansan/atomate/config/my_qadapter.yaml’, ‘/data_piglet/lansan/atomate/fw_tutorials/queue/queue_tests/my_qadapter.yaml’]
Choosing as default: /data_piglet/lansan/atomate/config/my_qadapter.yaml
2017-12-07 20:36:10,186 INFO moving to launch_dir /data_piglet/lansan/atomate/fw_tutorials/queue/queue_tests
/data_piglet/lansan/atomate/atomate_env/lib/python3.4/site-packages/fireworks/queue/queue_adapter.py:142: UserWarning: Key logdir has been specified in qadapter but it is not present in template, please check template (/data_piglet/lansan/atomate/atomate_env/lib/python3.4/site-packages/fireworks/user_objects/queue_adapters/SLURM_template.txt) for supported keys.
.format(subs_key, self.template_file))
2017-12-07 20:36:10,187 INFO submitting queue script
2017-12-07 20:36:10,191 ERROR ----|vvv|----
2017-12-07 20:36:10,192 ERROR Running the command: sbatch caused an error…
2017-12-07 20:36:10,194 ERROR Traceback (most recent call last):
File “/data_piglet/lansan/atomate/atomate_env/lib/python3.4/site-packages/fireworks/user_objects/queue_adapters/common_adapter.py”, line 204, in submit_to_queue
p = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
File “/usr/lib64/python3.4/subprocess.py”, line 856, in init
restore_signals, start_new_session)
File “/usr/lib64/python3.4/subprocess.py”, line 1460, in _execute_child
raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: ‘sbatch’
2017-12-07 20:36:10,194 ERROR ----|^^^|----
2017-12-07 20:36:10,195 ERROR ----|vvv|----
2017-12-07 20:36:10,195 ERROR Error writing/submitting queue script!
2017-12-07 20:36:10,196 ERROR Traceback (most recent call last):
File “/data_piglet/lansan/atomate/atomate_env/lib/python3.4/site-packages/fireworks/queue/queue_launcher.py”, line 136, in launch_rocket_to_queue
raise RuntimeError('queue script could not be submitted, check queue ’
RuntimeError: queue script could not be submitted, check queue script/queue adapter/queue server status!
Seems like a lot of errors. I am fairly new to FireWorks and would really like to configure this to our cluster.
Ralph
parallel_group2.sh (1.32 KB)
