Conversion from unscaled coordinates to unwrapped coordinates
I have performed a simulation, and have exported the trajectory in the following format:
dump trj all custom 1000 2.6.Trajectory.dump id mol type q x y z ix iy iz vx vy vz fx fy fz
Now, I would like to get the coordinates in my trajectory in unwrapped form (xu, yu, zu).
Can I use rerun command to export my trajectory in the following format:
dump trj all custom 1000 2.6.Trajectory.dump id mol type q xu yu zu vx vy vz
I would be grateful for any suggestions.
Thank you.
Sanjeet
Why don’t you just give it a try?
Also, you could use the dump class from tools/python/pizza/dump.py which is an updated version (for Python3 compatibility) of the dump class in pizza.py: https://lammps.github.io/pizza/doc/dump.html
Dear Axel,
Thank you for your reply.
I will try to do as you said.
Thank you,
Sanjeet
Dear Axel,
With the help of rerun command I am able to convert my trajectory from unscaled to unwrapped form.
Thank you for your help.
Sanjeet
