I would like to generate the disordered crystal structure of the sigma phase by using atat. However, I met a problem that when I choose different range of triplets to reach perfect match, I got the same atomic coordinates but different atomic species on the crystal sites. Is this normal? How to explain?
The parameter I select is as following:
(corrdump -l=rndstr.in -ro -noe -nop -clus -3=5)
(corrdump -l=rndstr.in -ro -noe -nop -clus -3=8)
Which triplet range do you think I should choose?
Thanks a lot for your help in advance!
The lattice file and output bestsqs.out are as following:
rndstr.in
9.70994 0 0
0 9.70994 0
0 0 4.99235
1 0 0
0 1 0
0 0 1
0.3967675469680074 0.3967675469680074 0.0000000000000000 Mo=0.5 Re=0.5
0.6032324530319926 0.6032324530319926 0.0000000000000000 Mo=0.5 Re=0.5
0.1032324530319926 0.8967675469680074 0.5000000000000000 Mo=0.5 Re=0.5
0.8967675469680074 0.1032324530319926 0.5000000000000000 Mo=0.5 Re=0.5
0.4640361093373215 0.1288191745165363 0.0000000000000000 Mo=0.5 Re=0.5
0.5359638906626785 0.8711808254834637 0.0000000000000000 Mo=0.5 Re=0.5
0.3711808254834637 0.9640361093373215 0.5000000000000000 Mo=0.5 Re=0.5
0.6288191745165363 0.0359638906626785 0.5000000000000000 Mo=0.5 Re=0.5
0.0359638906626785 0.6288191745165363 0.5000000000000000 Mo=0.5 Re=0.5
0.9640361093373215 0.3711808254834637 0.5000000000000000 Mo=0.5 Re=0.5
0.1288191745165363 0.4640361093373215 0.0000000000000000 Mo=0.5 Re=0.5
0.8711808254834637 0.5359638906626785 0.0000000000000000 Mo=0.5 Re=0.5
0.1824849424607962 0.1824849424607962 0.2526780385684688 Mo=0.5 Re=0.5
0.8175150575392109 0.8175150575392109 0.2526780385684688 Mo=0.5 Re=0.5
0.3175150575392038 0.6824849424607891 0.7526780385684688 Mo=0.5 Re=0.5
0.6824849424607891 0.3175150575392038 0.7526780385684688 Mo=0.5 Re=0.5
0.3175150575392038 0.6824849424607891 0.2473219614315312 Mo=0.5 Re=0.5
0.6824849424607891 0.3175150575392038 0.2473219614315312 Mo=0.5 Re=0.5
0.1824849424607962 0.1824849424607962 0.7473219614315312 Mo=0.5 Re=0.5
0.8175150575392109 0.8175150575392109 0.7473219614315312 Mo=0.5 Re=0.5
0.0000000000000000 0.0000000000000000 0.0000000000000000 Mo=0.5 Re=0.5
0.5000000000000000 0.5000000000000000 0.5000000000000000 Mo=0.5 Re=0.5
0.7403340999518946 0.0660324486047799 0.0000000000000000 Mo=0.5 Re=0.5
0.2596659000481054 0.9339675513952201 0.0000000000000000 Mo=0.5 Re=0.5
0.4339675513952201 0.2403340999518946 0.5000000000000000 Mo=0.5 Re=0.5
0.5660324486047799 0.7596659000481054 0.5000000000000000 Mo=0.5 Re=0.5
0.7596659000481054 0.5660324486047799 0.5000000000000000 Mo=0.5 Re=0.5
0.2403340999518946 0.4339675513952201 0.5000000000000000 Mo=0.5 Re=0.5
0.0660324486047799 0.7403340999518946 0.0000000000000000 Mo=0.5 Re=0.5
0.9339675513952201 0.2596659000481054 0.0000000000000000 Mo=0.5 Re=0.5
bestsqs.out
9.709940 0.000000 0.000000
0.000000 9.709940 0.000000
0.000000 0.000000 4.992350
1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
0.396768 0.396768 1.000000 Mo
0.603232 0.603232 1.000000 Re
0.103232 0.896768 0.500000 Mo
0.896768 0.103232 0.500000 Re
0.128819 0.464036 1.000000 Re
0.464036 0.128819 1.000000 Re
0.535964 0.871181 1.000000 Re
0.871181 0.535964 1.000000 Re
0.035964 0.628819 0.500000 Mo
0.371181 0.964036 0.500000 Mo
0.628819 0.035964 0.500000 Mo
0.964036 0.371181 0.500000 Mo
0.182485 0.182485 0.252678 Mo
0.182485 0.182485 0.747322 Mo
0.817515 0.817515 0.252678 Mo
0.817515 0.817515 0.747322 Mo
0.317515 0.682485 0.752678 Re
0.317515 0.682485 0.247322 Re
0.682485 0.317515 0.752678 Re
0.682485 0.317515 0.247322 Re
1.000000 1.000000 1.000000 Re
0.500000 0.500000 0.500000 Mo
0.066032 0.740334 1.000000 Re
0.740334 0.066032 1.000000 Mo
0.259666 0.933968 1.000000 Mo
0.933968 0.259666 1.000000 Re
0.759666 0.566032 0.500000 Re
0.433968 0.240334 0.500000 Mo
0.566032 0.759666 0.500000 Mo
0.240334 0.433968 0.500000 Re
bestsqs_02.out
0.396768 0.396768 1.000000 Re
0.603232 0.603232 1.000000 Mo
0.464036 0.128819 1.000000 Mo
0.871181 0.535964 1.000000 Mo
0.035964 0.628819 0.500000 Re
0.628819 0.035964 0.500000 Re
0.182485 0.182485 0.252678 Re
0.182485 0.182485 0.747322 Re
0.817515 0.817515 0.252678 Re
0.317515 0.682485 0.752678 Mo
0.317515 0.682485 0.247322 Mo
0.682485 0.317515 0.247322 Mo
1.000000 1.000000 1.000000 Mo
0.500000 0.500000 0.500000 Re
0.740334 0.066032 1.000000 Re
0.933968 0.259666 1.000000 Mo
0.759666 0.566032 0.500000 Mo
0.566032 0.759666 0.500000 Re
diff bestsqs.out bestsqs_02.out
7,8c7,8
< 0.396768 0.396768 1.000000 Mo
< 0.603232 0.603232 1.000000 Re
12c12
< 0.464036 0.128819 1.000000 Re
14,15c14,15
< 0.871181 0.535964 1.000000 Re
< 0.035964 0.628819 0.500000 Mo
17c17
< 0.628819 0.035964 0.500000 Mo
19,21c19,21
< 0.182485 0.182485 0.252678 Mo
< 0.182485 0.182485 0.747322 Mo
< 0.817515 0.817515 0.252678 Mo
23,24c23,24
< 0.317515 0.682485 0.752678 Re
< 0.317515 0.682485 0.247322 Re
26,28c26,28
< 0.682485 0.317515 0.247322 Re
< 1.000000 1.000000 1.000000 Re
< 0.500000 0.500000 0.500000 Mo
30c30
< 0.740334 0.066032 1.000000 Mo
32,33c32,33
< 0.933968 0.259666 1.000000 Re
< 0.759666 0.566032 0.500000 Re
35c35
< 0.566032 0.759666 0.500000 Mo
