Dear LAMMPS users,
While carrying out simulations on uranium dioxide (system containing both Coulomb and non-Coulomb interactions) using the 11Aug2017 version of LAMMPS, I found that, for the same atomic configuration, the code computes different values of the potential energy depending on the number of CPUs. I also found that, in fact, it was the Coulomb part of the potential energy which was impacted by the number of CPUs.
Below, you can find the results of Coulomb energy calculation on the same initial configuration of a 4x4x4 perfect UO2 supercell using different numbers of CPUs. The LAMMPS input file is also shown.
Result of the calculation run on 4 CPUs:
Ewald initialization …
WARNING: Using polynomial approximation for long-range coulomb (…/kspace.cpp:321)
G vector (1/distance) = 0.9
estimated absolute RMS force accuracy = 1.35346e-05
estimated relative force accuracy = 9.39924e-07
KSpace vectors: actual max1d max3d = 25441 23 51911
kxmax kymax kzmax = 23 23 23
Per MPI rank memory allocation (min/avg/max) = 44.8 | 44.8 | 44.8 Mbytes
Step PotEng TotEng
0 -9648.0006 -9648.0006
1 -9659.2292 -9659.2291
Loop time of 0.0401284 on 4 procs for 1 steps with 768 atoms
Result of the calculation run on 8 CPUs:
Per MPI rank memory allocation (min/avg/max) = 44.74 | 44.74 | 44.74 Mbytes
Step PotEng TotEng
0 -9644.1998 -9644.1998
1 -9655.331 -9655.3309
Loop time of 0.0155909 on 8 procs for 1 steps with 768 atoms
Result of the calculation run on 16 CPUs:
Per MPI rank memory allocation (min/avg/max) = 44.68 | 44.68 | 44.68 Mbytes
Step PotEng TotEng
0 -9636.9063 -9636.9063
1 -9647.8521 -9647.8519
Loop time of 0.00958024 on 16 procs for 1 steps with 768 atoms
The LAMMPS input file:
atom_style atomic
atom_modify map array
read_data C_UO2.in
fix 1 all property/atom q
set type 1 charge 2.2208
set type 2 charge -1.1104
pair_style coul/long 9.991
pair_coeff * *
kspace_style ewald 1e-6
kspace_modify gewald 0.9
pair_modify table 0
timestep 0.0002
fix 2 all npt temp 20.0 20.0 0.02 iso 0.0 0.0 0.2
thermo 1
thermo_style custom step pe etotal
run 1
As can be seen in the output files, the Coulomb energy (PotEng of the first configuration, for example) depends on the number of CPUs, despite the fact that the calculations are carried out for the same set of atomic coordinates (so the Coulomb potential energy should be identical !).
What could be the cause of this discrepancy? If you have an answer, please let me know.
Thank you,
A.J.
