Hi Lammps peopĺe!
I am trying to couple Lammps to other code and would like to see if
someone can help me in some difficulties.
As a starting point, I am trying to compile the example included
in ~/examples/COUPLE/lammps-quest
It was possible to build lammps as a library, using a modification of
the Makefile.openmpi file and a file called liblammps_openmpi.a was
created.
After that, when I try to compile the lmpqst.cpp using
make -f Makefile.openmpi
I receive the error message ():
lmpqst.o: In function `quest_callback(void*, long, int, int*, double**, double**)':
lmpqst.cpp:(.text+0x42): undefined reference to `lammps_extract_global'
lmpqst.cpp:(.text+0x5a): undefined reference to `lammps_extract_global'
lmpqst.cpp:(.text+0x72): undefined reference to `lammps_extract_global'
lmpqst.cpp:(.text+0x8a): undefined reference to `lammps_extract_global'
lmpqst.cpp:(.text+0xa2): undefined reference to `lammps_extract_global'
lmpqst.o:lmpqst.cpp:(.text+0xba): more undefined references to `lammps_extract_global' follow
lmpqst.o: In function `main':
lmpqst.cpp:(.text.startup+0x113): undefined reference to `LAMMPS_NS::LAMMPS::LAMMPS(int, char**, ompi_communicator_t*)'
lmpqst.cpp:(.text.startup+0x11f): undefined reference to `LAMMPS_NS::Input::file(char const*)'
lmpqst.cpp:(.text.startup+0x146): undefined reference to `LAMMPS_NS::Modify::find_fix(char const*)'
lmpqst.cpp:(.text.startup+0x166): undefined reference to `LAMMPS_NS::FixExternal::set_callback(void (*)(void*, long, int, int*, double**, double**), void*)'
lmpqst.cpp:(.text.startup+0x188): undefined reference to `LAMMPS_NS::Input::one(char const*)'
lmpqst.cpp:(.text.startup+0x190): undefined reference to `LAMMPS_NS::LAMMPS::~LAMMPS()'
collect2: error: ld returned 1 exit status
make: ** [lmpqst] Erro 1
it seems to me that the compiler doesn't find
which is a function included in the library.cpp code, included in
~/src
Can someone indicate to me how to make this function to be found ?
Thank you in advance,
Ricardo
