thanks for answers
I have a problem about crack .I made changes to the code that you see below. And by applying force and speed, my plate should be cut off from the notch and pre-crack. but this does not happen, and only the tension in the area has increased.
Thanks for your advice.
#this is my file
units si
boundary s s p
atom_style peri
atom_modify map array
neighbor 0.0012 bin
create geometry
lattice sc 0.0006
region plate block -0.0125 0.0125 -0.0285 0.0285 -0.004 0.004 units box
create_box 7 plate
create_atoms 1 region plate
region center_circle sphere 0 0 0 0.005 units box
group center_circle region center_circle
delete_atoms group center_circle
region crack block -0.0125 -0.0095 0 0.0002 -0.004 0.004 units box
group crack region crack
delete_atoms group crack
pair_style peri/lps
pair_coeff * * 2.89e9 1.05e9 0.002005 0.03867 0.22
pair_coeff 3 4 2.89e9 1.05e9 0 0.03867 0.22
set group all density 1180
set group all volume 36e-8
velocity all set 0.0 0.0 0.0 sum no units box
region 4 block INF INF -0.0095 0 INF INF units box
group low region 4
region 5 block INF INF 0.0002 0.0095 INF INF units box
group up region 5
set group low type 4
set group up type 5
fix 1 all nve
velocity up set 0 0.0005 0 units box
Raplace
fix 4 up setforce 0 3.09e8 0
velocity low set 0 -0.0005 0 units box
Raplace
fix 3 low setforce 0 -3.09e8 0
compute 1 all damage/atom
timestep 3e-8
thermo 20
dump 1 all custom 20 dump.lammpstrj id x y z c_1
dump 2 all xyz 20 dump.xyz
run 500
