Hi everybody. I am getting repeated “Angle atoms missing” errors when trying to equilibrate Kremer-Grest polymers via the “DBH” (Auhl 2003) method. The command I’m using to do the bond/angle swapping is standard, i.e.
fix 4 all bond/swap 10 0.5 1.3 598101
After a short number of steps (typically a few thousand), the run crashes with errors like
ERROR on proc 18: Angle atoms 98824 98822 98823 missing on proc 18 at step 4360 (…/ntopo_angle_all.cpp:68)
These errors are clearly associated with the fix; if I reduce the swap attempt fraction (the ‘0.5’ in the above line) to zero, no errors occur.
They tend to occur faster the more processors I run the job on. For this system, results are:
Nproc Crashes on timestep #
27 4360
24 3450
20 8110
16 3210
12 5110
8 6030
6 11630
4 13350
2 24420
1 none? no crashes after 150k steps.
This is for a system of 107 flexible chains, each containing 2800 monomers, at standard K-G melt conditions (rho = .85, T = 1) with all the usual parameters. No thermodynamic quantities are blowing up before these crashes. The above crash-timestep numbers reproduce if I repeat the runs. The atoms involved don’t repeat, they’re not always on the same chain or anything like that.
Any idea what could be causing this? I’ve been doing DBH runs for years and set up this run the same way I always have. I suspect that the trend with Nproc implies there’s some sort of interprocessor-communication glitch (that can be resolved by editing my LAMMPS script; there’s nothing wrong with the machine I’m running this on) that’s causing this. For reference, my input script is
high-T const-V DBH equilibration for Nch = 107 N = 2800 kb = 0 Kremer-Grest chains
units lj
atom_style angle
special_bonds lj 0 1 1
read_data data.kb0.Nch.107.N.2800.endoffastpushoff
neighbor 0.3 bin
pair_style lj/cut 1.12246
pair_coeff * * 1.0 1.0 1.12246
pair_modify shift yes
bond_style fene
rem start off with weaker FENE bonds
bond_coeff 1 10 1.5 1.0 1.0
angle_style cosine
angle_coeff 1 0
set Tinit to 1
velocity all create 1.0 2358365 dist gaussian mom yes rot yes
fix 1 all nve/limit 0.05
fix 2 all langevin 1 1 1 4528641 zero yes
compute msd all msd com yes
fix 3 all ave/time 1 1 1000 c_msd[4] file diffusion
DBH bond swapping
dump 1 all custom 2000000 configs.eq.constP.DBH id mol type x y z ix iy iz
rem need dump bondlist so can reoorder into correct chains
compute 2 all property/local btype batom1 batom2
dump 2 all local 2000000 bonds.eq.constP.DBH index c_2[1] c_2[2] c_2[3]
output double-bridging statistics
variable 1 equal f_1
variable accept equal f_4[1]
variable attempt equal f_4[2]
timestep .01
thermo 100
thermo_style custom step temp etotal epair ebond eangle press vol v_accept v_attempt
restart 4000000 equilib.res
run 4000000
increase FENE k
bond_coeff 1 15 1.5 1.0 1.0
run 4000000
increase FENE k
bond_coeff 1 22.5 1.5 1.0 1.0
run 4000000
back to normal FENE k
bond_coeff 1 30 1.5 1.0 1.0
run 4000000
Any help would be appreciated
Rob
