create_bonds with style single/improper
I would like to use the “create_bond” command to add a few improper torsion to my system. I can see in the manual that allowed styles are "many or single/bond or single/angle or single/dihedral". I was able to use these without any problem.
Is there any “single/improper” style available ?
Thanks in advance,
Bernard
I would like to use the "create_bond" command to add a few improper
*many* or *single/bond* or *single/angle* or *single/dihedral"*. I was
Is there any "single/improper" style available ?
​if it is not in the manual, it is not available (yet).
you might be able to do the same with the topotools plugin of VMD or just
edit the data file manually in a text editor.
axel.​
