Dear Lammps users
I am trying to creating molecules in a block void on a metal surface, here is my input:
units real
atom_style charge
region box block -10 10 -10 10 -10 10 units box
create_box 3 box
lattice fcc 3.52
create_atoms 3 region box
region void block -10 10 -10 10 0 10 units box
region void1 block -10 10 -10 10 -10 -6 units box
region void2 union 2 void void1
delete_atoms region void2
pair_style reax/c NULL
pair_coeff * * ffield.reax H O Ni
fix eem all qeq/reax 1 0.0 10.0 1e-6 reax/c
neighbor 2 bin
neigh_modify every 10 delay 0 check no
mass 1 1.007940
mass 2 15.999400
mass 3 58.69
group nickel type 3
velocity nickel create 300 4928459 rot yes dist gaussian
fix 1 all temp/rescale 1 300 300 10.0 1.0
fix 2 all nvt temp 300.0 300.0 10.0 drag 2.0
timestep 0.1
thermo 100
run 2000
unfix 2
change_box all boundary p p f
region water block -10 10 -10 10 6 10 units box
molecule mymol water.txt
create_atoms 0 random 10 123 water mol mymol 123456
fix wall all wall/reflect zhi EDGE
group water type 1 2
velocity water create 300 4928459 dist gaussian rot yes
fix 10 water temp/rescale 1 300 300 10.0 1.0
fix 3 all nvt temp 300 300 10.0 drag 2
thermo 100
timestep 0.1
run 2000
after creating 30 atoms in water region, two lines reported and simulation stopped:
step2000-hbondchk failed: H=0 end(H)=1 str(H+1)=0
application called MPI_Abort(MPI_COMM_WORLD, -14) - process 0
i change many commands in my input several times but it reports again and again,what does it mean and how can i solve it?
Best Regard.
