I am new to this software. Anyone has any idea how to make a geometry like this?
a cube which has a cylinder in it. (their materials are different)
I already have made the cube by this command:
region box block 0 0.05 0 0.02 -0.0005 0.0005 units box
but I don't know how to make a cylinder in it with a different material.
I would be thankful if anyone can help me with that!
Sayna Ebrahimi
Graduate Research Assistant
Mechanical Engineering Department
University of South Alabama, Mobile, AL
you can define a cylinder region
can do unions and intersections
of regions. by using a smart combination
of those, you can do what you want.
have a closer look at the documentation
of the region command (again).
I appreciate your previous help again. I could define my desired geometry consists of a plane that there is a cylinder in it. Do you know how I can define properties of two different materials for the plane and the cylinder separately? I have the properties below for the plane (form this paper: http://www.sandia.gov/~mlparks/papers/PDLAMMPS.pdf ) which appears in the commands below in my code:
pair_style peri/pmb
pair_coeff * * 8.601e22 0.0015001 0.0005 0.25
set group all density 2800
set group all volume 0.000000000125
I don't know how to determine pair_coefficients for another material.
Thank you very much in advance.
Sayna Ebrahimi
Like all pair styles, the coeffs you define with the pair_coeff command
are based on atom type. You can create atoms with different types
in your different geometric regions if you use the region and create_atoms
command judiciously.
