Creating arrays in LAMMPS
I was to do a simulation there I vary the control temperature in NPT according to the list T = [300,200,300,400].
Specifically, I want to have a loop that runs for a certain number of timesteps, changes the temperature, and continues the loop forward. Something like,
> label loopa
> variable a loop 15
>   print "$a"
>   fix     fx2 all  npt temp ${T[$a]} ${T[$a]} 0.5 aniso ${P} ${P} 5.0
>   run           500
>   unfix   fx2
>   write_data    data.out.*
>   write_restart data.restart.*
> next a
> jump SELF loopa
I am having some trouble defining the variable T in LAMMPS. Any suggestions?
Regards,
Please keep in mind that the LAMMPS input syntax is not a complete programming language and not meant to be one.
There are no indexed arrays in LAMMPS. However, the functionality you desire (looping over a sequence of numbers) can be easily implemented with an index style variable that holds the list of numbers and is used instead of the loop variable.
Thank you! This works perfectly!
Regards,
