I am using the following script to create TiN with NaCl structure.
variable a_TiN equal 4.22843688099911
clear
boundary p s p
atom_style atomic
atom_modify map array
variable Length_Y_TiN equal (8 * v_a_TiN) variable Length_XZ equal (8 * v_a_TiN)
region box block (-v_Length_XZ) (v_Length_XZ) (-v_Length_Y_TiN) ( v_Length_Y_TiN ) (-v_Length_XZ) (v_Length_XZ) units box
create_box 2 box
lattice fcc {a_TiN} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region Layer_N block (-v_Length_XZ) (v_Length_XZ) (-v_Length_Y_TiN) (v_Length_Y_TiN) (-v_Length_XZ) $(v_Length_XZ) units box
create_atoms 1 region Layer_N
lattice fcc {a_TiN} origin 0.5 0.0 0.0 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region Layer_Ti block (-v_Length_XZ) (v_Length_XZ) (-v_Length_Y_TiN) (v_Length_Y_TiN) (-v_Length_XZ) $(v_Length_XZ) units box
create_atoms 2 region Layer_Ti
However, when I want to use different crystallographic orientation I get a simulation box which is non-periodic in x and z directions:
lattice fcc {a_TiN} orient x 1 -1 0 orient y 1 1 1 orient z -1 -1 2
lattice fcc {a_TiN} origin ??? ??? ??? orient x 1 -1 0 orient y 1 1 1 orient z -1 -1 2
Actually, even without type 2 atom and simply reorienting just fcc structure with atom type 1, the boundary condition along x and z is non-periodic. By the way, I am not sure how to use the origin option to insert second fcc structure with atom type 2 after reorientation to get the NaCl structure.
Many thanks for your help and stay safe,
Reza.
