I’m new using LAMMPS. Is possible create a system containing a cylindrical particle surrounded of some kind of atoms? If possible, how I can do that?
I'm new using LAMMPS. Is possible create a system containing a cylindrical
what kind of potential and parameters do you want to use for that?
I think LJ potential.
then perhaps the tri/lj style in combination with lj/cut could work for you:
http://lammps.sandia.gov/doc/pair_tri_lj.html
http://lammps.sandia.gov/doc/pair_lj.html
alternately, you might want to experiment with fix wall/region for the
cylinder shape
http://lammps.sandia.gov/doc/fix_wall_region.html
http://lammps.sandia.gov/doc/region.html
