crystal orientation in BCC crystal
Hii all,
I have been working with BCC crystal in crystal orientation (001). Now , I have to orient the z axis of simulation box in [111] direction of crystal. I have used the following command as per given in the manual.
lattice bcc 3.304 origin 0.0 0.0 0.0 orient x 1 -1 0 orient y 1 1 -2 orient z 1 1 1
On running the script
The log.lammps file shows following:
Lattice spacing in x,y,z = 4.67256 5.39541 5.7227
Can anyone tell how is this lattice spacing being calculated by LAMMPS? Is it primitive unit cell dimensions?
regards,
Nidhi.
Hii all,
from the documentation of the lattice command:
If the spacing option is not specified, the lattice spacings are
computed by LAMMPS in the following way. A unit cell of the lattice is
mapped into the simulation box (scaled and rotated), so that it now
has (perhaps) a modified size and orientation. The lattice spacing in
X is defined as the difference between the min/max extent of the x
coordinates of the 8 corner points of the modified unit cell (4 in
2d). Similarly, the Y and Z lattice spacings are defined as the
difference in the min/max of the y and z coordinates.
for more information, please check out (all of)
https://lammps.sandia.gov/doc/lattice.html
