I am trying to run the example given in the examples/message directory, which shows how to use LAMMPS as both a client and server code to run an MD simulation. I built LAMMPS (v. 7Aug19) to be run in parallel, along with its MESSAGE package (but without ZMQ support).
I understand we also need to build CSlib to enable message exchange between the client and the server. To build that, I built the serial and parallel shared lib without ZMQ support in lammps/lib/message/cslib/src directory, by running ‘make shlib zmq=no’.
However, when I run the following lines in the shell script provided:
mpirun -np 1 lmp_mpi -v mode file -log log.message.client.file.g++.1 < in.message.client &
mpirun -np 1 lmp_mpi -v mode file -log log.message.server.file.g++.1 < in.message.server
I get the following error:
LAMMPS (7 Aug 2019)
CSlib ERROR: constructor(): CSlib invoked with MPI_Comm but built w/out MPI support
LAMMPS (7 Aug 2019)
I am confused why the error says CSlib was built without MPI support. I thought CSlib was built correctly, since I find both the libcsmpi.so and libcsnpmpi.so files in the lammps/lib/message/cslib/src directory. Could you please guide me as to what is going wrong? From the CSlib documentation, I seem to have followed all the required steps. Any suggestion would be very helpful.
Thank you!
Regards,
Vrindaa
