Hello LAMMPS users,
I intended to perform a simulation using the Streitz-Mintmire (CTI+EAM) potential on an RVE consisting of Al2O3. However, I was unable to run a multi-core simulation. I use the below command to start a multi-core simulation and I usually don’t have any problem with any other potential:
lmp_serial -pk omp #cores -sf omp -in input.in
Do you have any idea on how to obviate this problem?
It is worth mentioning that I’ve checked this problem on different computers and different versions of LAMMPS, however, it is still unable to use the cores.
