Custom Pair Potential
I am looking to define a specific kind of pairwise potential, which depends not on the distance between 2 atoms, but rather on the distance of each atom to a corresponding reference position.
Say I have two atoms at positions x and y, and their corresponding reference positions x0 and y0. Then, I would like the pairwise potential between positions x and y to be
U(x, y) = K * (x - x0) * (y - y0).
Is this possible to do in LAMMPS? Note that if positions x and y were the same, this would reduce to
U(x) = K * (x - x0)^2,
which is the harmonic bond style. But I am looking for the case where positions x and y are different. Any suggestions for how to accomplish this would be much appreciated!
Andrew Xu
Please have a look at fix spring/self.
Axel.
Dear Axel,
The fix spring/self (and fix spring) commands would solve the problem for the case of
since the force would simply be
F(x) = -K * (x - x0).
However, I am looking for the case where for two atoms at separate positions, x and y, the forces are
F(x) = -K * (y - y0),
F(y) = -K * (x - x0).
In other words, the force on atom x depends on the position of atom y at every time step, and vice versa. Is there a way for LAMMPS to do this? Or would I have to write my own potential?
Andrew
i don’t think there is anything like this. the closest that i can think of is this:
https://lammps.sandia.gov/doc/pair_nb3b_harmonic.html
but that is not quite what you describe. perhaps it would be a starting point for writing your own, though.
It might just be me, but potential does not appear to be bounded from below.Are you sure this is what you want?
I see; it is unfortunate that such a potential does not already exist. Could you please suggest some references or guides for writing our own potentials?
Regarding Stefan’s question that my potential
is not bounded from below, it should be, because the positions of the atoms are constrained by the dimensions of the simulation box.
Andrew
There is a whole section in the LAMMPS manual about modifying and extending LAMMPS. Axel.
I see, thanks for the pointer.
Andrew
