Hi lammps users,
we made a new pair_style called with files:
pair_prog.cpp
pair_prog.h
user_style.h
In user_style.h we have added then following:
#ifdef PairInclude
#include “pair_prog.h”
#endif
Everything compiles but when i try to run lammps and type in: pair_style prog we get:
ERROR: invalid pair style
Nithin
Hi lammps users,
pair_prog.cpp
pair_prog.h
user_style.h
#ifdef PairInclude
#include "pair_prog.h"
#endif
prog we get:
there is a lot of information missing here, e.g.:
- which version of LAMMPS is for?
- what platform are you on?
- where did you get the instructions to edit a "user_style.h" file?
- did you recompile after adding the files?
- what does your PairStyle() macro look like and what is your pair_style
command?
- Since I am taking over a project of a previous student, I am using an
older version of lammps: lammps-20feb10.
consider upgrading. many, many, many bugs have been fixed and many, many
improvements added over the last 7 years.
depending on how complex the pair style is, there changes are likely to be
fairly small.
this is too old a version for any developers to seriously care about
addressing any problems with it.
in almost all cases, it is highly advisable to upgrade, especially when you
are new to a project.
- I am using MAC OS Sierra v 10.12.3.
- I did not get these instructions from the website, I was told to do so
by my collegeaue who made the original code.
in current LAMMPS versions, no manual changes are needed. you type "make
mpi" and any *_style.h file will be automatically updated, if there are new
source files added. for your old version, you have to refer to the manual
for this specific version.
- Yes I did recompile them successfully.
- What do you mean with PairStyle() macro, where can I find it?
it should be in pair_<yourstyle>.h this macro matches pair_style
commands with individual pair style classes.
I’ve spotted the mistake. The following was missing in the header file:
#ifdef PAIR_CLASS
PairStyle(prog,PairProg)
